abs codes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">im getting a code 4 and 2 for the abs what are they? </TD></TR></TABLE>
for your specific year and model , it is the ABS rear gonkulator valve,, quite a common problem on those years
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">I already replied to your PM and BTW the code is 4-2</TD></TR></TABLE>
cool thanks for the help by the way its a 92 accord ex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ParoXoN »</TD></TR><TR><TD CLASS="quote">4-2 is the front-left wheel velocity sensor, I think.
[Edit]
Finally found my abs code list. That's the one.[/edit]</TD></TR></TABLE>
you are correct........
here is what you do, ...First off do a visual inspection make sure everything looks in order, no broken wires etc etc..if all looks good
, disconnect the plug at wheel sensor frt left and chk the resistance ,you need a multimeter ,...resistance should be 700 to 1100 ohms,, if it is out of this scale replace wheel sensor, remove abs b2 fuse for about 30 seconds to clear the computer , reinstall fuse and retry ..
[Edit]
iRIDEdumped
Jul 11, 2007 06:12 PM
CrxSiRyder
Sep 20, 2005 01:14 PM
