abs codes
Old Apr 6, 2006 | 06:16 PM
e jay one's Avatar
Default abs codes
im getting a code 4 and 2 for the abs what are they?
Old Apr 6, 2006 | 09:10 PM
gianinline's Avatar
Default Re: abs codes (e jay one)
what year? what model? ....any info will help YOU!!!
Old Apr 7, 2006 | 06:36 AM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">im getting a code 4 and 2 for the abs what are they? </TD></TR></TABLE>
for your specific year and model , it is the ABS rear gonkulator valve,, quite a common problem on those years
Old Apr 7, 2006 | 07:32 AM
Ross 2.0's Avatar
In a Junkyard near you.
I already replied to your PM and BTW the code is 4-2
Old Apr 7, 2006 | 04:59 PM
e jay one's Avatar
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">I already replied to your PM and BTW the code is 4-2</TD></TR></TABLE>
cool thanks for the help by the way its a 92 accord ex
Old Apr 7, 2006 | 06:08 PM
ParoXoN's Avatar
Default Re: (e jay one)
4-2 is the front-left wheel velocity sensor, I think.
[Edit]
Finally found my abs code list. That's the one.[/edit]
Old Apr 8, 2006 | 06:19 PM
e jay one's Avatar
Default Re: (ParoXoN)
where can i find this list at? helms?
Old Apr 8, 2006 | 10:55 PM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ParoXoN &raquo;</TD></TR><TR><TD CLASS="quote">4-2 is the front-left wheel velocity sensor, I think.
[Edit]
Finally found my abs code list. That's the one.[/edit]</TD></TR></TABLE>
you are correct........
here is what you do, ...First off do a visual inspection make sure everything looks in order, no broken wires etc etc..if all looks good
, disconnect the plug at wheel sensor frt left and chk the resistance ,you need a multimeter ,...resistance should be 700 to 1100 ohms,, if it is out of this scale replace wheel sensor, remove abs b2 fuse for about 30 seconds to clear the computer , reinstall fuse and retry ..
Old Apr 9, 2006 | 10:44 AM
e jay one's Avatar
Default Re: (accord-pro)
cool thanks
iRIDEdumped
Jul 11, 2007 06:12 PM
Josh Vertiz
Dec 15, 2006 04:00 PM
accordredliner
Oct 3, 2005 11:49 AM
CrxSiRyder
Sep 20, 2005 01:14 PM
vti-R
Dec 26, 2001 08:59 AM
