Max size of wheel spacer w/o needing extended lugs...
Old Apr 6, 2006 | 12:14 PM
Daily Interlude's Avatar
Default Max size of wheel spacer w/o needing extended lugs...
I've searched high and low and cannot find an answer to this question. I only need max 3/16" (~5mm) to clear my brakes to use these bogart drag rims/tires. Anyone know if I get a 5mm spacer that if it would require me to get extended lugs? How about a 3MM?
TIA
Old Apr 9, 2006 | 05:53 PM
Green JDM-R's Avatar
Default Re: Max size of wheel spacer w/o needing extended lugs... (Daily Interlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daily Interlude &raquo;</TD></TR><TR><TD CLASS="quote">I've searched high and low and cannot find an answer to this question. I only need max 3/16" (~5mm) to clear my brakes to use these bogart drag rims/tires. Anyone know if I get a 5mm spacer that if it would require me to get extended lugs? How about a 3MM?
TIA</TD></TR></TABLE>
3mm will be fine and you should be ok with 5mm also. What kind of vehicle is it?
Old Apr 9, 2006 | 06:28 PM
88 Honda Prelude...
Old May 10, 2006 | 11:06 AM
Jeremy D. Swain's Avatar
Default Re: (Daily Interlude)
I've always heard 5mm was as big as you should go, without using extended lugs.
Old May 10, 2006 | 01:33 PM
nsxtasy's Avatar
H-T Order of Merit
It's not based on mm. It's based on how many turns of the lug nuts. You should have an absolute minimum of six full turns on the lug nuts, although seven is even better.
Old May 11, 2006 | 10:10 PM
bc_ef8's Avatar
I broke a wheel stud w/ a 5 mm spacer. I don't recommend more than 3 mm w/ factory studs.
Old May 23, 2006 | 11:48 AM
poch915's Avatar
Default Re: (bc_ef8)
i got the same problem ..................but sorry to jack but where can i get 3mm spacers from tire shops? wheels shops? maybe
Old May 23, 2006 | 01:42 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (poch915)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poch915 &raquo;</TD></TR><TR><TD CLASS="quote">where can i get 3mm spacers from tire shops? wheels shops?</TD></TR></TABLE>
Nope. You can sometimes find them at auto parts stores. Otherwise, you can get them shipped from places like R&S Racing.
99Sir99
Apr 5, 2011 08:56 PM
SaYjAiBaO
Mar 26, 2007 10:15 PM
RUBZERK
Feb 5, 2004 05:36 AM
Smokinsax
May 7, 2003 11:22 AM
PROFILES2000
Feb 21, 2002 07:41 PM
