sounds like abs is going off all the time
Old Apr 6, 2006 | 11:41 AM
str8sleepr's Avatar
Default sounds like abs is going off all the time
Wassup guys i was just wondering if anyone else was having their abs go off at start up and on regular stops. (i.e. stop lights, traffic) I have a 94 civic and i always hear the abs go off. Anyone know how to fix this?
Old Apr 6, 2006 | 02:06 PM
str8sleepr's Avatar
Default Re: sounds like abs is going off all the time (str8sleepr)
anyone
Old Apr 6, 2006 | 02:35 PM
jdmeg9's Avatar
are you talking about that brrrrr sound when you start your car?
Old Apr 6, 2006 | 03:11 PM
str8sleepr's Avatar
Default Re: sounds like abs is going off all the time (jdmeg9)
yah... sounds like that... is that abs? that brrrrr sounds keeps going off
Old Apr 6, 2006 | 03:19 PM
schardbody's Avatar
does the pedal drop then rise real quick. sounds like the valve body is losing pressure, once the pressure is low inside the cylinder the pump will kick on to reset the piston in the cylinder. if it happens at lights and stuff, like RIght before you come to a stop and the pedal kicks a little you most likely have a tone ring on your axle or rear hub thats got a damaged spot.
Old Apr 6, 2006 | 03:30 PM
str8sleepr's Avatar
Default Re: (schardbody)
yah the pedal drops and then rises real quick.
Old Apr 6, 2006 | 03:42 PM
schardbody's Avatar
yeah, if it does it right before a stop then you got a tone ring thats dented or has built up rust on it. MOST likely cause, there are others.
Old Apr 6, 2006 | 05:25 PM
str8sleepr's Avatar
so just replace the axle?
Old Apr 6, 2006 | 05:27 PM
schardbody's Avatar
i wouldnt say that. you can look at the rings on the axles, if there are any gouges on them or dents its going to cause the problem. there are other things that will cause it but thats the most likely. also, im not sure if you can just buy the tone rings, but at my shop we can get them, we just swap them from one axle to the other.
EG civic
Nov 11, 2020 11:44 PM
felixjr18
Dec 21, 2008 07:22 PM
eric416
Oct 9, 2008 04:05 PM
94_teggy_rs
Jan 28, 2008 08:36 PM
dremmel
Apr 21, 2003 04:22 PM
