need help for install an exedy clutch
Old Apr 6, 2006 | 01:25 AM
ivt-t's Avatar
Default need help for install an exedy clutch
i have bought a slightly used double disc exedy clutch.
but cannot find any instructions to install it.
please give me some.
Old Apr 6, 2006 | 12:44 PM
vaporboy12's Avatar
Default Re: need help for install an exedy clutch (HybridKOOP)
its easy put the fly wheel one then first disc then the floater plate then next disc line the wholes on this one with the small whole on the disk agiant the flywheel....put next floater on then pressure plate then put bolts in put aliment tool in then Tq bolts to 22 ftq
Old Apr 6, 2006 | 04:54 PM
Speedworks801's Avatar
Default Re: need help for install an exedy clutch (vaporboy12)
The disc that goes next to the flywheel has "FW" stamped on it as well so you can tell the difference. If you need more help just e-mail me.
Good luck!
Old Apr 6, 2006 | 10:01 PM
ivt-t's Avatar
Default Re: need help for install an exedy clutch (Speedworks801)
thank you for help,but my problem is that the pressure plate is fully dis assambled.
i dont find any pics how should it look.
Old Apr 7, 2006 | 04:21 AM
Turbocivic94's Avatar
Default Re: need help for install an exedy clutch (civiccoupehybrid)
From my experience, buying a used clutch is like buying a used condom.
Old Apr 7, 2006 | 04:37 AM
ykracing's Avatar
Default Re: need help for install an exedy clutch (Turbocivic94)
I work at exedy, send me your email, and I'll send you the install instructions.
Bseries hydro cerametallic twin plate right?
bboixtc
Mar 28, 2008 06:52 PM
zerovandez
Mar 10, 2007 11:08 AM
ScottEK
May 27, 2003 07:11 PM
ModlesSI
May 15, 2003 07:07 AM
