Preparations for ACT HDSS Install?
New User
About to install my ACT HDSS clutch and pressure plate. Is there anything i should get beforehand to avoid trips to the store? I believe the factory pressureplate is held onto the clutch disk via 6 bolts while when i look @ the ACT clutch, it has holes for 9 bolts? What size are these bolts? Any other tips for the clutch, or ACT Streetlite flywheel installs?
Thanks in advance.
EDIT: This is going into a b16a2 tranny.
Thanks in advance.
Re: Preparations for ACT HDSS Install? (ModlesSI)
It has 9 holes but u only use 6. The other 3 are for the pins that are on the flywheel to hold the plate in place. The pressure plate also can only go on one way, ie the 3 pins can all only fit in place with the pressure plate in the right place.
Buzzbomb
Transmission & Drivetrain
04-18-2010 04:21 AM
HARI.
09-25-2005 11:04 AM
