Will this ecu work??
Old Apr 5, 2006 | 08:19 PM
juniestyle's Avatar
Default Will this ecu work??
I have a 99 civic si and im doing a motor swap! Im swapping it to a 2000 gsr motor...i was wondering will my ecu for the civic si work on the gsr?
Old Apr 5, 2006 | 08:30 PM
mmuller's Avatar
Mad Scientist
Default Re: Will this ecu work?? (juniestyle)
it will work, but not good..
Old Apr 5, 2006 | 09:34 PM
juniestyle's Avatar
what do you mean by not good?
Old Apr 6, 2006 | 02:42 PM
juniestyle's Avatar
Anyone else know?
Old Apr 6, 2006 | 04:03 PM
mmuller's Avatar
Mad Scientist
vtec will be higher up in the rev range from the 4400. no control of iab's.
conservative timing compared to gsr maps on high cam.
Old Apr 6, 2006 | 05:05 PM
ultrablackhatch's Avatar
Default Re: Will this ecu work?? (mmuller)
The only thing good about the si ecu is that it doesn't have butterflys so you can get a better flow. But you will also need a better intake manifold. Correct me if i'm wrong
Old Apr 6, 2006 | 05:48 PM
juniestyle's Avatar
so the b16a2 ecu will make the gsr motor hit vtec later than it would with the gsr ecu?
Old Apr 6, 2006 | 07:03 PM
juniestyle's Avatar
someone please reply
Old Apr 6, 2006 | 10:10 PM
juniestyle's Avatar
anyone?
Old Apr 7, 2006 | 12:14 AM
Edgecrusher's Avatar
you could chip the ECU w/ uberdata or something along those lines. the only thing you would be lacking is IAB control because i'm pretty sure the si ECU does not have an IAB output. for more info on uberdata, check out this site:
http://home.mn.rr.com/keebler65/honda
Old Apr 7, 2006 | 02:24 PM
juniestyle's Avatar
Default Re: Will this ecu work?? (Edgecrusher)
thanx for the reply...im definitly going to check it out...but what is IAB?
Old Apr 21, 2006 | 12:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juniestyle &raquo;</TD></TR><TR><TD CLASS="quote">thanx for the reply...im definitly going to check it out...but what is IAB?</TD></TR></TABLE>
Intake Air Butterflys (present in all B18C1 manifolds).
Old Apr 21, 2006 | 01:51 PM
juniestyle's Avatar
thanx...so basically vtech wont hit early as it would do for a b18c1 ecu...am i correct?
Old Apr 21, 2006 | 03:07 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juniestyle &raquo;</TD></TR><TR><TD CLASS="quote">thanx...so basically vtech wont hit early as it would do for a b18c1 ecu...am i correct?</TD></TR></TABLE>
it's VTEC.
the B16 ECU will run the GSR leaner than it should be run.
It will set VTEC point higher than the GSR wants it.
it will not open the secondary intake runner.
Pick up a P72, run the extra wire and enjoy the C1.
Old Apr 21, 2006 | 05:55 PM
BlueSi2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edgecrusher &raquo;</TD></TR><TR><TD CLASS="quote">you could chip the ECU w/ uberdata or something along those lines. the only thing you would be lacking is IAB control because i'm pretty sure the si ECU does not have an IAB output. for more info on uberdata, check out this site:
http://home.mn.rr.com/keebler65/honda</TD></TR></TABLE>
the 99 si ecu is obd2, you cant' chip it. i wouldn't run it...do what the guy above me says
Old Apr 21, 2006 | 10:22 PM
juniestyle's Avatar
oops...i forgot im boosting it...will that make a difference!!!
Old Apr 24, 2006 | 06:56 AM
juniestyle's Avatar
bump~
Old Apr 24, 2006 | 08:38 AM
Relic1's Avatar
to run boost properly you need to convert to OBD1 and tune it.
ef2hondaboi
Jun 23, 2009 04:33 PM
nk cs
11
Aug 6, 2008 03:25 PM
blackie
Nov 8, 2005 05:52 AM
808b18c1boosted
Jan 11, 2004 08:59 AM
turbod16y8
Dec 16, 2002 02:20 PM
