99-00 harness in a 96-98
Old Apr 5, 2006 | 04:08 PM
fluxekhatch's Avatar
Default 99-00 harness in a 96-98
ok putting my civic stock motor back in i need to know if a 99-00 harness will work in a 96 car. i have the 99 ecu.. please help me..
Old Apr 5, 2006 | 04:52 PM
ROOROWNS's Avatar
If your asking whether OBD2b harness will power an OBD2a vehicle...
yes as i recall a later obd2 will be able to jive with a earlier obd2 interior harness.
Maybe an extra connector
wait for other confirmation.
Old Apr 7, 2006 | 11:22 AM
Default Re: (.No_Honda.)
bump!!
Old Apr 7, 2006 | 12:35 PM
civicstar's Avatar
Default Re: (fluxekhatch)
it should work, unless its an SI, Sis dont work in the other modles becuz 2 clips on the harness go to the ecu and then the car has its own wire running the the ecu
Old Apr 7, 2006 | 06:18 PM
b18ccivics's Avatar
Default Re: (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">it should work, unless its an SI, Sis dont work in the other modles becuz 2 clips on the harness go to the ecu and then the car has its own wire running the the ecu</TD></TR></TABLE>
i dont know if this is true maybee
but i do know an 99-00 si engine harness has 2 plugs that go directly to the ecu, and a 98 civic engine harness has 3 plugs that go to the ecu and they are not interchangeable.
Old Apr 8, 2006 | 05:41 PM
bump!
Old Apr 9, 2006 | 10:39 AM
top
Old Apr 12, 2006 | 01:29 PM
bumpo
Old Apr 13, 2006 | 05:31 PM
top
Old Apr 13, 2006 | 06:33 PM
ReDHaTcHyGuy's Avatar
it will work if u swap in the 99 interior dash harness.. otherwise no.... u need the same year harness
_oemek_
Dec 13, 2010 10:00 PM
HondaPartsHero
13
Nov 24, 2006 09:30 PM
colinproctor
16
Feb 21, 2005 03:37 PM
B18ek
Nov 27, 2004 07:39 AM
d0nkeyxPunch
Apr 16, 2003 08:18 AM
