Bead Blasting Head
Old Apr 13, 2006 | 12:59 PM
spoonek9's Avatar
Default Bead Blasting Head
When having a head cleaned and work, is it a good idea for them to bead blast the internals of the head? I'm particuarly talking about cam bearing surfaces.
Old Apr 13, 2006 | 01:28 PM
msmotorsports's Avatar
Default Re: Bead Blasting Head (spoonek9)
DO NOT bead blast the internals of the head. Only do the exterior for cosmetic purposes. If you sandblasted the cam journals it would be like spinning the cams on fine grit sandpaper once reassembled.
Old Apr 13, 2006 | 06:38 PM
Combustion Contraption's Avatar
Walnut shell media is ok, as long as theyre not using sand or steel it should be fine. Just make sure its cleaned very thoroughly once its finished. But i still wouldnt do it.
del spool
Nov 28, 2010 02:52 PM
TheCrimsonGhost666
Aug 4, 2010 11:22 PM
ten2doyle102
Feb 6, 2009 07:32 PM
the.hamburglar
11
Jun 28, 2006 02:10 PM
Lewdin' Incognito
Jul 22, 2005 12:35 AM
