f/s: used HKS MBC and EVO8 16G turbo
posting for a buddy of mine. any questions post a reply or PM me. thanks.
USED HKS MBC. Bleedoff style. Easy to install with existing hoses. Used for 6 months. Good condition. 50.00 bucks baby
Website http://www.hksusa.com/products/?id=857
USED 16G EVO VIII TURBO 04GSR Good condition 20K miles on turbo. The turbo has two bolts that need to be extracted (located on the exhaust manifold/turbo flange) by the new owner (read: I am to lazy to do it myself, go to a machine shop and get it done after you buy it) bolts are shown in the pic below. Turbo comes with everything shown (oil lines, coolant lines, ect.) Turbo does not come with the manifold or O2 housing. 300.00
Modified by YaMaJeSty at 8:03 AM 4/10/2006
Modified by YaMaJeSty at 12:34 PM 4/10/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Gurgla GSR »</TD></TR><TR><TD CLASS="quote">question about the mbc
is this the model for the internal or external gate?</TD></TR></TABLE>
i'll PM you and edit the post when i find out.
it's for the internal, but this is a bleeder style boost controller. it doesn't matter if you have internal or external it will work for both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">what are the specs of it?
what is the stock internal wg PSI setting?
is it oil & coolant cooled?
what about of WHP is it good up to?
1. td05hr-16g6-9.8t
2. factory actuator is included and it's set to ~12 PSI (not exact though)
3. it is setup for both water and oil
4. WHP depends on your motor and whatever else you have on it. EVO's generally see up to 400WHP with this snail with no problem.
1. td05hr-16g6-9.8t
02 housing was sold to someone already. i can probably find one if you really want one with it. about $40-50 maybe? or you can get a nice one from lancershop.com for about $100
turbohf
Apr 17, 2003 01:49 PM
