compression vs power
Old Apr 5, 2006 | 12:39 AM
Accord CVCC's Avatar
Default compression vs power
is milling the head or deck to gain compression say from 8.8 to 10 to 1 going to actually gain anything other then more expenisve fillups? 5% 10 % loss of top end revs? more low end torque? after doin test to make sure your valves arent gonna touch your pistons that you have a head gasket rated for it ( is felpro safe to use?) and whats roughly the max compression you can safely run with 91 octane?
carberated cvcc old school
Old Apr 7, 2006 | 11:54 AM
89a6T's Avatar
Default Re: compression vs power (Accord CVCC)
to bump up that much it is not recommended that you raise compression in that manner. un less its a bs motor that you dont care aboutand want to use as a paper weight in a couple months.
Old Apr 7, 2006 | 12:34 PM
civicstar's Avatar
Default Re: compression vs power (89a6T)
when ur all motor, the compression matters. the top end cams, like stage 2 skunk2s and todas spec bs and up require alot of compression. when its all motor, the compression and displacement matters, the higher the compression, the more power. same with turbo, at high boost, its just like a high compression motor.
soon2bdropped
Oct 3, 2007 06:28 PM
josh green
Oct 23, 2004 03:03 PM
SpoolnG2
Mar 21, 2003 07:02 AM
98civicEX
Jul 31, 2002 07:16 PM
HX_Guy
Dec 6, 2001 03:24 PM
