Clutch wont disengage..
Old Apr 4, 2006 | 10:48 PM
JFG Kevin's Avatar
Default Clutch wont disengage..
My clutch wont disengage completely when i push down my clutch all the way down. What might cause this to happen? So far there is a new tranny, throw out bearing, and pilot bearing. My clutch hasn't been used for that long maybe only 8000 miles on it. It's a ACT street.
Old Apr 4, 2006 | 11:37 PM
ImportMotorSpec's Avatar
Default Re: Clutch wont disengage.. (aznstyler119)
There is either air in the clutch line causing not enought pressure to disengage, bad clutch master cylinder seal, or bad clutch slave cylinder seal.
Tre bleeding the clutch first.
Old Apr 5, 2006 | 12:18 AM
JFG Kevin's Avatar
Default Re: Clutch wont disengage.. (ImportMotorSpec)
yah..i was thinkin about bleeding the clutch...would the fluid be it? i look at the fluid..it's pretty damn BLACK...haha...could it ever be the Pressure plate? or a bad clutch disc?..i didn't change the master cylinder that long ago...hum...
Old Apr 5, 2006 | 12:48 AM
PurEvl's Avatar
yep bad pressure plate/disc will not allow u to shift gears or dissengage the clutch
Old Apr 5, 2006 | 03:27 AM
JFG Kevin's Avatar
Default Re: Clutch wont disengage.. (PurEvl)
it's not like it's not letting me into gear. It's just hella hard to get it int gear. I know the clutch will disengage but just not fully cause i and put it in first and see the car move forward just ever so slowly in my garage.
Old Apr 10, 2006 | 10:27 PM
apexipower321's Avatar
yeah im having the same problem . i think it's the pressure plate i have to turn off the car every time i stop to put it in first gear sucks.. what do u guys think it is??
Old Apr 10, 2006 | 10:37 PM
integra3586's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurEvl &raquo;</TD></TR><TR><TD CLASS="quote">yep bad pressure plate/disc will not allow u to shift gears or dissengage the clutch</TD></TR></TABLE>
happened to me
Old Apr 10, 2006 | 10:39 PM
Default Re: Clutch wont disengage.. (B18B-SC)
it could also be a bad master cylinder or slave. check to see if there is any fluid under the dash where is comes into the cabin.
Old Apr 10, 2006 | 10:50 PM
Default Re: (apexipower321)
any suggestions???
Old Apr 11, 2006 | 05:31 AM
purejdmsi's Avatar
try bleeding all the air out of the lines that what happened to me or if not check to see if the throw out bearing is still properly on the fork
Old Apr 11, 2006 | 09:46 PM
i have the transmisssion off now and the pressue plate was rusted and the pressure plate bolts were only hand tight..... that might have caused that haha
Old Apr 12, 2006 | 01:56 AM
OUT OF ORDER ROB's Avatar
bleed that ****!
supersilverdc2
Transmission & Drivetrain
11
Jan 16, 2014 12:45 PM
langjairicer
May 1, 2010 12:08 AM
dragonkx
21
Mar 28, 2010 06:47 PM
joedeo72
Jun 7, 2008 01:14 PM
94accord718
Sep 19, 2007 07:42 PM
