EK hatch LS swap help..
Okay i've searched but i have'nt found the specific imformation i'm looking for. I've swapped a LS swap into my old EG no problem just dropped in and plug and play..
I now wanna swap a ek hatch what parts are needed has far has motor mounts,shift linkage,axles and from what car will the axles that come with the swap be fine?..Can the shift linkage be modified?? Which motor mounts need to be replaced and with what kind??
I was told by the company i was gonna buy my swap from that 1 of the mounts have to be changed.. Can anybody give some concrete info. I'm doing a LS swap probably a obd-1.. i already have the jumper harness from obd-2 down to obd-1..
the rear bracket and the drivers upper mount have to be changed. If you want to keep AC you'll need either a del-sol vtec mount or a crv mount.
http://www.phear7imports.net/trey/6gen/
Linkage and axles from teg work
jdmeg1075
May 8, 2009 09:35 AM
gabe30
Mar 15, 2005 07:14 AM
