95 ex w/ b18c1 vtec not working car boggs
vtec works when i rev it for a sec.then it starts bogging.dont kknow what else to do?car boggs at like 3000 rpm. no engine light no codes.i have a p28 chipped ecu.what else could it be?????????????????
it could be that you are running a p28 ecu and the gsr has IAB sensor on the manifold. the butterflies arent opening so vtec is bogging out. what chip is in the ecu? if you dont wanna run the gsr manifold, just get a skunk, blox, or aebs. that will eliminate the IAB
just unplug the iab sensor. the chipped p28 will not recognize the iab's anyway. when your car is off the iab's are open. as soon as you turn the key on it closes. there are some people who use zip ties to leave them open. i have the same set-up and i just swapped in a skunk2 mani... it was worth it.
310HPS2k
24
Oct 12, 2009 10:22 PM
