My VTECH doesn't work :(
VTEC WONT KICK!? HELP ME FIND OUT WHY
I wired my ek shell (CX) for vtec. Now it wont work/kick/pop in. I have to run the o2 sensor still because they are still short and i have to run the speed sensor. Will any of these two sensors disable my vtec from popping? let me know
ps im running the harness to a harness jumper over to obd1 p28 chipped. When i run the GSR P72 that came with the motor, when vtec is supposed to kick the engine makes like its rev limiting and wont let the rpms go past were the vtec is supposed to pop. Thats why im using the chipped p28
Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (thewonderer)
off the top of my head. before the vtec to activate there are few things that it required. oil pressure, speed...
i dont think the o2 will affect it but the speed sensor (you have to be going 15mph for vtec to engage i think or something like that) and reason its hittin "rev limit" is you should be throwin a vtec system malfunction CEL which shuts your car down right at vtec engagement point
Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (xavenged7x)
Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (screech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screech »</TD></TR><TR><TD CLASS="quote">i dont think the o2 will affect it but the speed sensor (you have to be going 15mph for vtec to engage i think or something like that) and reason its hittin "rev limit" is you should be throwin a vtec system malfunction CEL which shuts your car down right at vtec engagement point</TD></TR></TABLE>
I believe its 20mph and the car has to be at running temperature before it will kick in.
BTW, are you running a P28 or an ECU w/ VTEC? (I don't know if the CX motors came w/ VTEC or not)
Re: (jlacoy82)
I believe jla is right on this one from what i know i dont think Vtec will work with any check engines on, and even so yes the car has to be warmed up before Vtec will kick on.
Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">VTEC doesnt work if you're throwing any CEL's.</TD></TR></TABLE>
bullshit
only certain CEL's will eliminate vtec.
VSS is one. but the VSS wont put it into limp mode
if you dont belive me unplug your o2 sensors and go for a drive. vtec will work and your CEL will be on.
bullshit
Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
bullshit
if you dont belive me unplug your o2 sensors and go for a drive. vtec will work and your CEL will be on. </TD></TR></TABLE>
WHERE IS MY O2 SENSUR?!?
bullshit
Re: (94_Del Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_Del Sol »</TD></TR><TR><TD CLASS="quote">o damn i thought this was about your VTECH phone...guess i cant help</TD></TR></TABLE>LOL, same here, i was gonna refer him to radio shack, they have a wide assortment of vtech phones so they could probabky fix it
Re: (Kamin)
lol when i slapped my vtec swap in my cx.. i still hit vtec with out wires from my ecu... and it was an 93... not 92... and no there were no wires... yeah weird,...?
well i donno bout ur prob man sorry good luck
Re: (al3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e »</TD></TR><TR><TD CLASS="quote">lol when i slapped my vtec swap in my cx.. i still hit vtec with out wires from my ecu... and it was an 93... not 92... and no there were no wires... yeah weird,...?
well i donno bout ur prob man sorry good luck </TD></TR></TABLE>
Nope.
Nope.
Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (BS 22)
if you have any check engine light your vtec wont work..... the only difference between obd1 and obd2 is that obd1 with a check engine light you can still take it to redline....
obd2 you will have a governer around 5 grand to 5,500
Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">if you have any check engine light your vtec wont work..... the only difference between obd1 and obd2 is that obd1 with a check engine light you can still take it to redline....
obd2 you will have a governer around 5 grand to 5,500</TD></TR></TABLE>
nope. as said before vtec can work with a cel. I know this for a fact because i've done it. The 5 grand governor is probably limp mode. limp mode only occurs with certain cels. 90% of the people who come on here claiming they are in limp mode really have no idea what limp mode is.
Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
nope. as said before vtec can work with a cel. I know this for a fact because i've done it. The 5 grand governor is probably limp mode. limp mode only occurs with certain cels. 90% of the people who come on here claiming they are in limp mode really have no idea what limp mode is.</TD></TR></TABLE>
correct - some ppl are just e-mechanics
