Transmission Question - Will a '95si 5spd work on a 97ex 5spd?
Old Apr 4, 2006 | 01:17 PM
PrecisionH23a's Avatar
Default Transmission Question - Will a '95si 5spd work on a 97ex 5spd?
Yes? No? Any further mods needed to be done to make one work?
Old Apr 4, 2006 | 01:30 PM
dohcVTECeg2's Avatar
Default Re: Transmission Question - Will a '95si 5spd work on a 97ex 5spd? (PrecisionH23a)
yes
Old Apr 4, 2006 | 01:40 PM
Default Re: Transmission Question - Will a '95si 5spd work on a 97ex 5spd? (dohcVTECeg2)
The mounts are the same too I take it?
Old Apr 4, 2006 | 01:45 PM
cxSHOE's Avatar
it is a bolt on part with your engine and car.
the only difference between the two transmissions is the later has a stronger shift arm lever.
Slopoke's Avatar
You need to put the '97 mount on the '95 transmission(upper mount).
It bolts right on.
Old Apr 4, 2006 | 01:55 PM
Bense's Avatar
Default Re: (Slopoke)
it bolts up fine, i believe the dust shield won't fit (so no mudbogging in the civic)
I have never heard of any mount issue existing between 92-95 and 96-00
aluminum shift forks only matter when you abuse the tranny.
soft aluminum forks break (breaking only the fork)
steel forks bend (taking other stuff out with it)
but that doesn't matter, because I am sure that you (or your customer) won't be abusing their transmission
Old Apr 4, 2006 | 02:11 PM
Crazydave's Avatar
Default Re: (Bense)
the si tranny also has a shorter 5th gear I believe
Old Apr 4, 2006 | 03:06 PM
Bense's Avatar
Default Re: (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">the si tranny also has a shorter 5th gear I believe
yup, del sol si and civic si (92-95) have a 0.750 instead of a 0.702
that 6.4% difference in gearing is the HUGE difference between the ex and the SPORTS VERSION!!!!!!
Old Apr 4, 2006 | 03:21 PM
dohcdelsol's Avatar
Default Re: (Bense)
Its not a plug in and play
You will need to re-wire the speed senser as the connections are different. Its a matter of cutting the old wires and soldering the correct sensor with the motor.
Old Apr 4, 2006 | 03:24 PM
Bense's Avatar
Default Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">Its not a plug in and play
You will need to re-wire the speed senser as the connections are different. Its a matter of cutting the old wires and soldering the correct sensor with the motor.</TD></TR></TABLE>
why not just use the old speed sensor...
Old Apr 4, 2006 | 03:29 PM
dohcdelsol's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
why not just use the old speed sensor...</TD></TR></TABLE>
It wont fit. If you disconnect the old sensor and try pluggin it into the new 97 sensor, the connection is different
just a simple solder job
ya know, come to think about it, i left the newer tranny sensor in. i didnt try to change out the old one and put it in the new tranny. But i know the plugs wont line up so all i didnt was clip and solder.
Modified by dohcdelsol at 7:42 PM 4/4/2006
Old Apr 5, 2006 | 11:08 AM
Mista Bone's Avatar
D Tranny Guru
turn the connetor 180, it plugs right in, so swap the VSS.
Yes they interchange, matter of fact you can install a 5g/6g VSS into a cable tranny, drops right in.
Bense, nice job holding down the fort here
Old Apr 5, 2006 | 11:12 AM
Bense's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">turn the connetor 180, it plugs right in, so swap the VSS.
Bense, nice job holding down the fort here </TD></TR></TABLE>
Old Apr 5, 2006 | 12:56 PM
Jakester9500's Avatar
I was wondering that same thing. I like cheap hp. I want two cam shafts, but until I get a career, the D is fun for tinkering.
Old Apr 5, 2006 | 01:08 PM
Bense's Avatar
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering that same thing. I like cheap hp. I want two cam shafts, but until I get a career, the D is fun for tinkering.</TD></TR></TABLE>
It's still fun to tinker with even when you do have a career!
what do I care about k20's I got a career!
Old Apr 5, 2006 | 08:29 PM
No, that's not what I meant. I would just prefer to have a B18b in my hatch than a d16y7. 106 hp is ****. I could get a different engine, that won't be tomorrow or anything. But that's just my opinion. I would like to get 160 out of a d though. Just so I can say I get 100 hp to the liter.
Old Apr 5, 2006 | 08:45 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">No, that's not what I meant. I would just prefer to have a B18b in my hatch than a d16y7. 106 hp is ****. I could get a different engine, that won't be tomorrow or anything. But that's just my opinion. I would like to get 160 out of a d though. Just so I can say I get 100 hp to the liter.</TD></TR></TABLE>
b-series parts are expensive. I just got a d-series dizzy shipped to me for 28 dollars. used b-series parts go for 2x-4x the amount of d-series
Linked
12
Mar 2, 2010 10:55 AM
DFW
Jan 8, 2007 01:16 PM
Rod.
Jul 12, 2005 11:23 AM
HondaCutter
Sep 15, 2002 08:35 PM
HondaCutter
Sep 15, 2002 07:16 PM
