Code 65 again.. ahh..
Old Apr 4, 2006 | 11:43 AM
pinoyboiwonder's Avatar
Default Code 65 again.. ahh..
how do i tell if they secondary o2 heater sensor is going bad? it keeps throwing this code.. ive posted about this before.. and it still wont go away blah.. i bought a new one too and put it on it still threw the code..
Old Apr 4, 2006 | 11:46 AM
1bad-eg's Avatar
Default Re: Code 65 again.. ahh.. (pinoyboiwonder)
Do you have a straight pipe or a high flow cat. where the stock one would be?
Old Apr 4, 2006 | 12:06 PM
its stock cat.. i tried resetin the ecu by pullin the battery cable.. and i wait for like 20 seconds.. put the battery cables back on and the ecu doesnt reset. throws same code. 65
Old Apr 4, 2006 | 12:13 PM
1bad-eg's Avatar
Default Re: (pinoyboiwonder)
Sounds like your o2 sensor is bad.
Old Apr 4, 2006 | 12:17 PM
i thought code 63 means your o2 sensor is bad..
Old Apr 4, 2006 | 12:30 PM
**DOHC HaTcH**'s Avatar
noob question: the o2 sensor checks temp in the exhaust... or exhaust flow??? idk any info would be cool
Old Apr 4, 2006 | 12:34 PM
dood this is wack ;(
Old Apr 4, 2006 | 07:21 PM
any 1?
Old Apr 4, 2006 | 07:22 PM
dont wanna waste my money and buy anotehr secondary o2 sensor if its fixable.. since its NOT throwing a code 63. its throwin a 65.
Old Apr 4, 2006 | 10:06 PM
anyone?..
Old Apr 11, 2006 | 06:15 PM
bump for an answer. i tried to reset ecu but it doesnt reset it just throws it again.
Old Apr 15, 2006 | 05:24 PM
bump its been like 2 weeks lol ive been patient.
Old Apr 15, 2006 | 07:38 PM
no one?
Old Apr 18, 2006 | 08:30 AM
deng no one? can help?
Old Apr 18, 2006 | 09:18 AM
EE_Chris's Avatar
Get a Helms.
Get a meter.
Measure the O2 heater resistance (as the Helms manual instructs one to do).
Spec is 15-40 ohms.
If it's out of spec, replace it. If it's in spec, follow the Helms troubleshooting outline for futher investigation. There aren't but 3 parts to this 'system': The O2 sensor itself, the wiring harness and the ECU. It's gonna get spendy replacing the other two vs troubleshooting correctly - your call.
Old Apr 24, 2006 | 07:58 PM
is it bad to drive with a code 65?
Old Apr 25, 2006 | 07:20 AM
EE_Chris's Avatar
I don't know. I generally fix what is broke on my car. I've found that leaving a problem go un-fixed only causes bigger problems down the road.
Old Apr 25, 2006 | 08:25 AM
any one know if its bad to drive with a code 65???????
importnoodles
Mar 29, 2008 10:20 AM
the jdmchop
May 23, 2006 11:26 AM
EG2 SiR
Mar 4, 2004 10:35 AM
S13 slide
Jun 2, 2002 03:30 PM
GSRacer
Oct 3, 2001 07:50 AM
