auto ek puttin in manual h22 swap
Old Apr 4, 2006 | 06:35 AM
CHAZegHATCH's Avatar
Default auto ek puttin in manual h22 swap
well have searched and cant fink a solid answer im puttin i jdm h22(already have the motor not gettin a different one) in a 98 auto ek hatch i know i need gauge cluster peddles, cluth master cylinder, and lines the motor i obd1 so i need a concersion kit but i am wondering if i will have 2 move pinns around and witch ones i will have 2 move need help!!
Old Apr 4, 2006 | 06:38 AM
o2flow.net's Avatar
Default Re: auto ek puttin in manual h22 swap (CHAZegHATCH)
Your search for h22 swap returned 942 results.
Start there.
Old Apr 4, 2006 | 07:12 AM
the jdmchop's Avatar
Default Re: auto ek puttin in manual h22 swap (o2flow.net)
geez ill try and help out a bit i hate when h-t ******** write search that **** sucks and youll be there for hours getting a open-ended answer, but some time the **** hits you in the face
well you need just the clutch pedal and assembly, i got it for 120 form honda!
no need for the whole set just the clutch pedal. clutch master cyl, resivour, clutch line( got mine from flamenco-T )
you would need a obd2-obd1 jumper and ecu!
get some mounts for the h-into ek
then you need to wire up reverse lights,yel/red and grn/blk to your reverse switch!
then the 2 blk and 1 blk/blu thick wires together to trick ecu that its in park
thats as much as i got for you!
im doin a z6 into my ek and have been searchin for a while now too
hope this helps
Old Apr 4, 2006 | 08:31 PM
Default Re: auto ek puttin in manual h22 swap (jdmchop)
cool so i dont have to do any repinning of the ecu 4 the auto 2 manual part but will i have to run the 2 blk and 1 blk/blu thick wires together to trick ecu that its in park sence i am goin to be runnin a chiped manual obd1 p28 i dont thank i shod just want a second option
Old Apr 5, 2006 | 04:21 AM
now wiring up the h22 to a ek body i have no clue about but i think they sell jumpers for it?
Old Apr 27, 2006 | 05:26 AM
ScottEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">geez ill try and help out a bit i hate when h-t ******** write search that **** sucks and youll be there for hours getting a open-ended answer, but some time the **** hits you in the face
hope this helps </TD></TR></TABLE>
I've been searching all weeek for some EK specific information, it seems that all auto-to-manual conversion threads are about EGs. I just want to clarify a couple things before I go parts shopping this weekend.
With an EK chasis you only need to add the clutch pedal, you dont need to switch out the brake/throttle or related cables?
Can you use any EG parts for doing this swap, or do I need to find all manual EK parts?
The auto pedal set has all the necessary holes for adding the clutch pedal?
Finally, is there already a hole in the fire will for master cylinder mounting?
Old Apr 28, 2006 | 02:47 PM
ScottEK's Avatar
Default Re: auto ek puttin in manual h22 swap (ScottEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuMP &raquo;</TD></TR><TR><TD CLASS="quote">
Finally, is there already a hole in the fire will for master cylinder mounting?</TD></TR></TABLE>
tegboy321
Oct 4, 2012 12:28 AM
Day-DayC
Transmission & Drivetrain
Mar 12, 2012 06:45 AM
93eg2james
Aug 18, 2006 08:55 PM
ScottEK
Apr 30, 2006 05:47 PM
Lude@Heart
Sep 7, 2005 10:59 AM
