auto to manual ek swap, need info
im going to do auto to manual swap on my ek and i have my wrecked 5 speed eg, i was wondering if i could use my clutch master cylinder and clutch lines off of my eg into my ek? same for pedals?
lmk HT!! need this info asap
Re: auto to manual ek swap, need info
pretty sure you'll need to buy a drop mount for the tranny... aside from that you can swap the mount off the drivers side and the t bracket mount should be ok to swap... and yes all of the clutch stuff with swap
Seagull Management
Clutch lines are completely different. MC is the same. brake pedal is different, clutch is the same.
For mounts you just need EK manual mounts and brackets, no custom swap mount required on an EK chassis.
I recently got done with my AUTO TO MANUAL SWAP EK also 1998
You need clutch plus lines from any 96-00 ex dx lx MANUAL
And instead of changing the whole brake to gas assembly you can just take the brake arm/pedal it self and remove your old auto arm/pedal to the manual 96-00 ex dx lx MANUAL not sure if the order models work
If you need help you can contact me and we can text !
toofast4you1989
09-15-2009 03:03 PM
93eg2james
08-18-2006 08:55 PM
