What size tig for welding aluminum cylinder head?
I was planning on fixing a deep scratch (2-3mm deep) on the deck of a cylinder head caused by shipping damaged, by adding some more metal to the area. Once this blog is attached to the head, I would have it surfaced, and smoothed out.
What size tig would be required to weld on basically onto a brick of aluminum? Would a new Miller Syncrowave 200 or Dynasty 200DX fit the bill? I was planning on picking up a tig to add to my collection of tools this summer, and thought this might be a fun project. I have 2 spare heads I can play around on before this one, and the task seems pretty simple as it is just adding a bit of filler metal into a cleaned out scratch that is prepped for welding. Not like joining 2 pieces of aluminum sheetmetal standing upside down inside a tunnel or anything
Big.
I wouldn't even try it with the sync200, and the only with the dynasty 200 if you preheat the hell out of it. A sync350 or dynasty300 would be a better choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 »</TD></TR><TR><TD CLASS="quote">Big.
I wouldn't even try it with the sync200, and the only with the dynasty 200 if you preheat the hell out of it. A sync350 or dynasty300 would be a better choice.</TD></TR></TABLE>
I've never done cast, but why would you need more amps? 3mm is ~1/8", so for full penetration of the crack you'd only need 160-180amps or so (and even less since it's preheated) - wouldn't a Sync200 be plenty?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF »</TD></TR><TR><TD CLASS="quote">Get a bottle of helium and put it on DC straight like your welding steel.And don't pre heat it. just weld it .You will be surprised</TD></TR></TABLE>
Might want some practice first.
but then you won't be surprised
</TD></TR></TABLE>but then you won't be surprised
haha i fixed a broken head on my car late night when the machine shops and what not wernt open with my 250 syncrowave. its still on a running car to this day
Guest
Posts: n/a
I have welded heads and thick *** alum.with a 180 air cooled with helium.The Helium burns so damn hot that you can just start welding without having to sit there all day with your foot in it looking for a shiny spot. But you can't EVEN weld thin **** though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">
but then you won't be surprised </TD></TR></TABLE>
lol!
lol!
if you preheat, and the scratch is only 3mm deep why would you need such a high amperage machine. i think 200 amps would be plenty. get the head to nice and warm {but not hot enough to warp the **** out of it} and rock out. you dont need 15 inches of penetration here.
maybe im crazy
maybe im crazy
BryanPendleton
May 7, 2004 08:19 AM
