NEED help with JDM corner lights! JDM FRONT OWNERS!
Old Apr 3, 2006 | 06:41 PM
Fliplm0de's Avatar
Default NEED help with JDM corner lights! JDM FRONT OWNERS!
My headlights didnt come with any wires or anything, so i was guessin you just relocate the oem USDM harness(two wedges or something) to connect them in the headlights, but the socket on the JDM headlights look like a 1156 or 1157, is there a way to use the USDM harness? or do i need to buy a different harness. if so anyone got some for sale?
Modified by Fliplm0de at 9:32 PM 4/3/2006
Old Apr 3, 2006 | 07:49 PM
Fliplm0de's Avatar
Default Re: NEED help with JDM corner lights! JDM FRONT OWNERS! (Fliplm0de)
Old Apr 3, 2006 | 08:06 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Just curious what you mean... JDM front end conversions have blinkers in the headlights and on the fenders... Corner lights???
Old Apr 3, 2006 | 08:32 PM
11mastamind11's Avatar
Default Re: NEED help with JDM corner lights! JDM FRONT OWNERS! (ForceFed_Motorsports)
he means the blinkers, not corner lights, i had my conversion done at a shop they needed a new harness if i can remember and a seperate harness for the fogs.
Fliplm0de's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Just curious what you mean... JDM front end conversions have blinkers in the headlights and on the fenders... Corner lights???</TD></TR></TABLE>
sorry, im talking about the blinkers in the headlights
Old Apr 3, 2006 | 08:33 PM
Fliplm0de's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11mastamind11 &raquo;</TD></TR><TR><TD CLASS="quote">he means the blinkers, not corner lights, i had my conversion done at a shop they needed a new harness if i can remember and a seperate harness for the fogs.</TD></TR></TABLE>
do you know what kind of harness it was?
Old Apr 4, 2006 | 02:59 PM
Fliplm0de's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fliplm0de &raquo;</TD></TR><TR><TD CLASS="quote">do you know what kind of harness it was?</TD></TR></TABLE>
Old Apr 4, 2006 | 06:17 PM
ninhers's Avatar
you should be able to use your orginal 1157 socket. just need to modify the socket a little to make it fit.
Old Apr 4, 2006 | 08:56 PM
Fliplm0de's Avatar
Default Re: NEED help with JDM corner lights! JDM FRONT OWNERS! (ninhers)
i dont have orignal 1157.. isn't 1157 kinda like a socket type bulb round tip, the harness i have from my USDM looks like 2 wedges that are flat
Old Apr 4, 2006 | 09:16 PM
ninhers's Avatar
on the stock usdm bumper lense, there are 2 bulbs. the outer ones are the small 168 wedge style bulbs and the 2 inner bulbs are the 1157 style bulbs. if you don't have the sockets, you should be able to pick some up at any auto parts store.
Old Apr 4, 2006 | 09:29 PM
RHDintegXsi's Avatar
i just stretched the bumper light harness, modified the socket a little and plugged it right in..
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Keep in mind that the corners lights for the JDM front end conversion only blink, they arent supposed to stay lit. The bulb/socket you need should be similar to your rear blinkers.
A 1157 bulb stays light AND blinks, but the socket wont fit the JDM headlight without some modification. You basically have to grind away the tabs on the socket. You can use this bulb/socket so that your corners will stay lit and blink, but that's not the way it was intended. Doesnt really matter though, it looks good either way.
Old Apr 4, 2006 | 10:42 PM
Default Re: NEED help with JDM corner lights! JDM FRONT OWNERS! (carma_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind that the corners lights for the JDM front end conversion only blink, they arent supposed to stay lit. The bulb/socket you need should be similar to your rear blinkers.
the plug has three wires..you can simply cut the parking light lead off the plug and it will only blink
Old Apr 5, 2006 | 02:01 PM
Fliplm0de's Avatar
Default Re: NEED help with JDM corner lights! JDM FRONT OWNERS! (SINFULintegXsi)
thanks for the info i needed
EK 2 9K
Dec 9, 2007 05:21 PM
Cboy1-EG6
31
May 5, 2005 12:45 PM
b16_madman
Apr 15, 2004 10:45 PM
V-Thang
Acura TL, RL & ZDX
Mar 11, 2004 03:41 PM
