Fuel injector
stock OBDI 240cc injectors are good on NA cars for up to about 180whp without issues with right fuel pump.
btw. DSM injectors require a resistor box to be wired even to work. Then ECU needs to be reprogrammed/tuned for the setup otherwise you're just flooding the cylinders.
yes it is a larger cc than your stock injectors. they need modification, hit up the search buttom under the archvied section. its all there ,everythign you need.
hysteria411
Engine Management and Tuning
26
Sep 30, 2013 06:12 PM
