motor mounts
Old Apr 3, 2006 | 01:53 PM
steve96accord's Avatar
Default motor mounts
what r some good motor mounts for an inexpensive price? And also i have bad *** wheel hop would motor mounts stop that?
Old Apr 3, 2006 | 01:59 PM
P_Adams's Avatar
Default Re: motor mounts (steve96accord)
Bad motor mounts will most definitely cause wheel hop.
As to your other question, I've never found Good (and inexpensive) Motor Mounts.
If you can stand the additional vibration, I'd go with Poly mount inserts. Either that or Factory items.
P
Old Apr 3, 2006 | 02:03 PM
Default Re: motor mounts (P_Adams)
One of my friends Has a Srt-4 an His putting some stuff called Flexane 94 its rudder but turns Hard as ****... Has anyone ever used it or heard Of it?
Old Apr 3, 2006 | 02:19 PM
P_Adams's Avatar
That particular product, no. But I have heard of the process. In effect, you're filling the voids left for flex and making it a solid rubber (silicone) mount.
P
Old Apr 3, 2006 | 02:21 PM
i_kick_turtles's Avatar
A good cheap alternative to poly mounts is to fill your mounts with urethane. I'm trying to find a write-up. I'll post it when I do.
Edit: http://www.cb7tuner.com/vbb/showthread.php?t=3033
Modified by I R Tylor at 5:38 PM 4/3/2006
Old Apr 3, 2006 | 04:06 PM
Default Re: motor mounts (I R Tylor)
Thanks..
Old Apr 3, 2006 | 06:10 PM
P_Adams's Avatar
I believe this is what you're talking about; and guess what, It's Urethane!!!
Flexane 94 Flexible Urethane (Black)
6,000 cps | 97A Shore Hardness
10 Min. Gel Time
This is a semi-rigid material which is extremely tough and abrasion resistant. Ideal for flexible molds and non-marring holding and assembly fixtures.
Flexane Urethanes contain no solvents and feature low shrink, high chemical and abrasion resistance
http://www.freemansupply.com/F...U.htm
P
Old Apr 3, 2006 | 08:56 PM
Yes sir, thats It. what u think about that product. think it would work Or not strong enuff to withstand that much force?
Old Apr 3, 2006 | 09:12 PM
BlUAc's Avatar
well what would you do just get the mount flush against something and pour it in
Old Apr 3, 2006 | 09:21 PM
CD7power's Avatar
Default Re: motor mounts (BlUAc)
how much does Flexane run for? where can you pick some of stuff at?
Old Apr 4, 2006 | 08:38 AM
NAiL05's Avatar
My friend filled his mounts with urethane on his jdm f22b they are stiff as hell but im not sure what product he uses. Filling and Inserts are a lot cheaper than buying a mount kit from Hasport and such.
Old Apr 4, 2006 | 10:53 AM
P_Adams's Avatar
Default Re: motor mounts (CD7power)
About $34.00 usd for the one pound (1lb) Devcon kit
http://www.superkleendirect.co....HTML
P
Old Apr 4, 2006 | 11:25 AM
jasontluong's Avatar
motor mounts, you should look for Energy Suspension motor mounts.
i highly recommended.
Old Apr 4, 2006 | 05:44 PM
CD7power's Avatar
Default Re: motor mounts (jtluong050696)
sweet, thanks P!
Old Apr 4, 2006 | 05:56 PM
raceACCORDingly's Avatar
i got 80a shore liquid urethane from mcmaster.com for $25. i have filled tranny and rear mount and inserts in the front mount. if you have an LX you can get Prothane rear inserts.
used this how to.
http://www.accordinglydone.com...=6037
Old Apr 4, 2006 | 09:49 PM
BlUAc's Avatar
Default Re: (raceACCORDingly)
sweet that looks sicc wit it but like i asked how do you go about putting it in
Old Apr 5, 2006 | 12:03 AM
i posted the link on the how to. its liquid, you mix the hardener in and then pour it into to mount with one side taped off.
alx_90ef
20
May 30, 2014 06:31 AM
ej1gsr!
Dec 14, 2011 09:24 PM
GuCBlackEk
Oct 2, 2008 06:06 AM
scabbs
Sep 17, 2007 09:57 AM
Rod.
Jul 2, 2005 11:49 PM
