Staying Obd1 With Type R SWAP
Old Apr 3, 2006 | 09:24 AM
egcivicdelsol's Avatar
Default Staying Obd1 With Type R SWAP
hey hows it goin everybody, i was planning on swapping a type r into my del sol. well i already have the swap anyway. i just got it refereed here in cali so i have the bar label so the 1.8 is legal all day. i dont want to convert my car to obd2, its too much work, or wiring. so i was told that if i used an obd1 wiring harness (which i happened to find a b16a3 del sol vtec wiring harness, which would fit perfectly) then an obd1 distributor, that i could keep it obd1? does anybody else have any information, or any tips of what i will need to do exactly to keep this type r obd1 in my car. i already have a chipped skunk2 ecu thats obd1 also. anything else that i might need? pls help, thx a lot.
Old Apr 3, 2006 | 11:42 AM
92civichatch1's Avatar
Default Re: Staying Obd1 With Type R SWAP (egcivicdelsol)
https://honda-tech.com/zerothread?id=1417060
you may wanna learn to use the search function.
Old Apr 3, 2006 | 12:35 PM
fmrprojects's Avatar
Default Re: Staying Obd1 With Type R SWAP (92civichatch1)
just keep the motor how it is and get a obd2 ger or ls harness. plug the harness on and it should all be plug and play. then just plug the ecu you have already in and you are good to go
EG_SINZ
14
Dec 12, 2011 03:23 PM
efrunner09
Sep 20, 2009 10:24 AM
advan414
Feb 25, 2008 02:28 PM
gohandbz8
14
Feb 21, 2004 05:18 PM
