Running Very Rich, HELP!
Old Apr 3, 2006 | 07:47 AM
9hatch6's Avatar
Default Running Very Rich, HELP!
whenever i get on it a ton of black smoke shoots out, mostly when it hits vtec. i know that a little is alright, but this is more then a little. what could it be? headgasket? and i do have a check engine light.
Old Apr 3, 2006 | 07:49 AM
vtakvtrak's Avatar
Default Re: Running Very Rich, HELP! (9hatch6)
could be valve seals, pistons, blown headgasket?... lots of possibility.
Old Apr 3, 2006 | 07:51 AM
9hatch6's Avatar
Default Re: Running Very Rich, HELP! (vtakvtrak)
how do i come to a conclusion? check to see what check engine light is?
Old Apr 3, 2006 | 09:33 AM
Ash81's Avatar
check what CEL code you are throwing and go from there..........by your passenger side kick panel theres a plug get a paperclip or wire connect both ends to it.......then get a helms book to see what code its throwing.......i think theres a thread on here that shows you how and what the codes are..........search is your friend.
Old Apr 3, 2006 | 09:49 AM
9hatch6's Avatar
Default Re: Running Very Rich, HELP! (Ash81)
thanks homies
Old Apr 3, 2006 | 09:55 AM
AbitAvenger's Avatar
Also try a compression and or leakdown test and it will let you know whats up.
Old Apr 3, 2006 | 12:09 PM
lightcrx's Avatar
car, motor, ecu, com'on we need more info than that .
-joseph
ph0shizzle
May 13, 2006 08:36 PM
01-0720
Feb 19, 2006 11:11 AM
zoopsta
14
May 1, 2005 05:39 AM
jeux
Jul 10, 2004 08:40 PM
halfNhalf-83
Mar 15, 2004 10:00 AM
