drained battery ??
ok i have a problem with my crx the battery dies with the car off after a few days something is drawing power from the battery
heres what iv tried pulled all the bulbs checked the altinator completly disconected the stereo swaped ecus out pulled all the fuses swaped out all the relays
what could be causeing this ?
do you happen to have a volt meter? If you do...you could start off by going to each fuse and check to see if theres power going to it...other possiblities could be fuel pump stays on or fan...electrical is a pain but goodluck
this is a friends car btw .. he's had 4 rand new batterys in it . .& he said he took out every light bulb in the car 2 see if one of the lights were causing it .
but i'll ask about the fuel pump & fan .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR »</TD></TR><TR><TD CLASS="quote">sounds like loose/corroded grounds and/or postive battery cable</TD></TR></TABLE>
yea check the grounds
civicboy420
27
Aug 20, 2014 07:53 PM
ekHatChAddIcT
15
Mar 16, 2011 06:58 PM
ludachrisvt
Sep 22, 2008 11:01 AM
