Compression test results? Little Low?
Old Apr 2, 2006 | 05:11 PM
mugenhatchie's Avatar
Default Compression test results? Little Low?
Just did a compression test. Motor is B18C1 stock stroke w/ wiesco 11.8:1 pistons and stock head gasket. WOT, Dry cylinders, 7 compression strokes. Here are the results:
Cyl 1 250
Cyl 2 245
Cyl 3 243
Cyl 4 251.
Does this seem normal for a high comp motor? Thanks!
Old Apr 2, 2006 | 05:17 PM
Combustion Contraption's Avatar
That seems about right to me, but people are going to come on here telling you that youre low.
Old Apr 2, 2006 | 05:22 PM
Default Re: Compression test results? Little Low? (mugenhatchie)
Motor only has about 8000 mile on it since we built it. Doesn't that seem kind of low for that milage??
Modified by mugenhatchie at 2:58 AM 4/3/2006
Old Apr 2, 2006 | 06:02 PM
EJ8tunerman's Avatar
That looks pretty good to me. I would probably expect about 265 across but that isnt bad.
Old Apr 2, 2006 | 06:33 PM
What do you think would be normal for a high compression motor?
Old Apr 2, 2006 | 09:21 PM
bump
Old Apr 2, 2006 | 10:48 PM
GetawayInMoscow's Avatar
As long as there isn't 20+ psi varience in the cylinders you are fine...
Old Apr 2, 2006 | 10:55 PM
The only reason I am worried is that about 3 months ago I tested it and it was at 270 across the board.
Old Apr 3, 2006 | 12:31 AM
fmrprojects's Avatar
did you test it when the motor was still hot? when the motor is hot the rings expand making a better seal. so thats maybe why you got higher #'s the other time. but those #s are good
slammedbbs
May 9, 2011 04:14 AM
aziaticvang
10
Feb 11, 2008 10:09 AM
sirguy01
Jul 6, 2006 09:03 PM
92integraVTECgsr
Jul 17, 2005 02:23 AM
sdinteg
Feb 1, 2005 07:52 PM
