LS VTEC PCT compression HELP!!!
my buddies building his LS VTEC, his set up is as follows:
LS B18B block
stock crank and rods
81mm Civic Type R (PCT) pistons
GSR head, untouched
skunk 2 stage 2 cams
my question is what kind of compression is he looking at? ive done compression calculators on 2 different sites, and i got 14.23:1 and 12.81:1... from some of the experienced, which one will be more accurate
also, assuming he tries running the stock headgasket, how close will the valves he to hitting the pistons with his skunk 2 cams? or will they hit?
any help would be greatly appreciated, thanks
LS B18B block
GSR head, untouched
compression should be around 12.2-12.3:1 dont know about piston valve contact tho. he doesnt plan on runnin those cams on stock springs&retainers doees he?
see here for more info.
https://honda-tech.com/zerothread?id=717928
I personally trust this site
http://www.zealautowerks.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">see here for more info.
that website greatly contrasts from the highly used c-speed calculator
lsvtec with pct pistons would not put out a 14.4:1 compresion ratio
this site is giving me over 14:1 compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c5_el »</TD></TR><TR><TD CLASS="quote">
this site is giving me over 14:1 compression</TD></TR></TABLE>
it seem to be very incorrect
use the calculator on c-speedracing.com
it is much more accurate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec »</TD></TR><TR><TD CLASS="quote">
lsvtec with pct pistons would not put out a 14.4:1 compresion ratio</TD></TR></TABLE>
How would you know? Have you clayed a motor to determine if it is wrong?
"highly used"? How do you know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c5_el »</TD></TR><TR><TD CLASS="quote">so 13.4:1 as posted by omniman is more correct?</TD></TR></TABLE> i always go to that thread with PCT pistons if you read what they did it seems correct.
"highly used"? How do you know?</TD></TR></TABLE>
because i know people who have built them, and everyone i know uses it and a 14.4:1 seems retardedly high to be able to run on 94 octane gas dont you think?
im not saying it is 100% correct but it seems close enough
ive learned from experience
ive learned from experience</TD></TR></TABLE>
Good enough
Good enough
vodkas22
12
May 30, 2006 08:37 PM
