Autometer A/F gauge!!
Old Apr 2, 2006 | 12:33 PM
D_CRX_Si's Avatar
Default Autometer A/F gauge!!
Well i justr installed a A/F gauge, and im not gettin a good reading..it goes to the bottom red light then starts fading out, if i give it gas then it jumps to the green and all the way bak to the red..Every thing is installed correct if im correct...It does not stay a constant color then move as you give it gas, it jumps back and forth..Any help on the problem this could be?
Old Apr 2, 2006 | 03:19 PM
8krdline's Avatar
Default Re: Autometer A/F gauge!! (D_CRX_Si)
they only read at WOT and arent 100% accurate
Old Apr 2, 2006 | 05:00 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Autometer A/F gauge!! (8krdline)
The reason why the gauge bounces all over the place is becuase the ECU is constantly tryin to adjust the AFR for a better mixture and better MPG. That gauge is just a light show and is not accurate for tuning purposes. You need a wideband 02 sensor to acurately monitor AFR.
Old Apr 2, 2006 | 05:44 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_CRX_Si &raquo;</TD></TR><TR><TD CLASS="quote">Well i justr installed a A/F gauge, and im not gettin a good reading..it goes to the bottom red light then starts fading out, if i give it gas then it jumps to the green and all the way bak to the red..Every thing is installed correct if im correct...It does not stay a constant color then move as you give it gas, it jumps back and forth..Any help on the problem this could be?</TD></TR></TABLE>
autometer's a/f gauge is a narrowband, it reads ONLY when you're at WOT. you need a wideband which will read the entire rpm band.
autometer a/f gauge: junk and bling
Urville
Jul 16, 2016 07:32 AM
TypRice
Honda Motorcycles
May 18, 2009 12:27 PM
ambat
Mar 7, 2004 09:16 PM
HybridHatchC1
May 6, 2002 06:03 PM
