leaking oil from THAT corner
Old Apr 2, 2006 | 11:24 AM
SPOOLINmatt's Avatar
Default leaking oil from THAT corner
my motor has been running for about 2 months now. its been slightly leaking from day one at that corner where the serial number is on the headgasket. its really annoying creating that eye sore of fresh oil on my block accross the "b18b" badge. is there any remedies for this, ive retorqued the head studs, both surfaces were machined. is there any kind of oil stop leak that can be purchased to stop crap like that?
Old Apr 2, 2006 | 04:49 PM
postman's Avatar
Default Re: leaking oil from THAT corner (SPOOLINmatt)
on the front right corner try exhaust cam seal on the end of the head
Old Apr 5, 2006 | 02:25 PM
Default Re: leaking oil from THAT corner (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">on the front right corner try exhaust cam seal on the end of the head</TD></TR></TABLE>
It is not any of those seals. 100% positive. its coming from the headgasket. its nothing major, just an annoyance.
Old Apr 5, 2006 | 02:51 PM
havok hybrid's Avatar
i would guess and say its your vtec soilnoid or dizzy seal.
Old Apr 5, 2006 | 03:01 PM
WickedSol's Avatar
you should really get that fixed...you say nothing major now but in time, if you run your motor hard, the head and/or block can warp. what kind of head gasket are you using? Use only OEM Honda! i recommend pulling the head off, resurface the head, buy some arp studs, make sure your block deck is flat, and slap everything on to torque spec and sequence. Good Luck!
Old Apr 5, 2006 | 04:59 PM
ROOROWNS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">It is not any of those seals. 100% positive. its coming from the headgasket. its nothing major, just an annoyance.</TD></TR></TABLE>
Where on the headgasket do you think the oil is leaking?
I almost bought a GSR with a leak in the exact same spot and the kid said " Ohh that oil, yeah everyone's gsr leaks there, its no big deal." I thought it was warped head or warped block.
Bump for a solid answer.
Old Apr 5, 2006 | 07:03 PM
hybridmiklo's Avatar
Default Re: leaking oil from THAT corner (.No_Honda.)
It has to be the cam cap on that side. Trust me. Just get one of those aftermaket cam cap seals and put it in. You will thank me later when you notice the oil is gone. The stock cam caps suck.
Old Apr 5, 2006 | 08:41 PM
JDMtype Eg6's Avatar
Default Re: leaking oil from THAT corner (hybridmiklo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmiklo &raquo;</TD></TR><TR><TD CLASS="quote">It has to be the cam cap on that side. Trust me. Just get one of those aftermaket cam cap seals and put it in. You will thank me later when you notice the oil is gone. The stock cam caps suck.
Thats what i think it is also, i thought my gasket was leaking at first when i looked at my oil leak, but followed the oil and saw that the bottom portin of the cam seal was wet. Replaced it with an aftermarket one and no more leak (its an easy fix). This is common for hondas especially w/ mileage on it. Pictures would be really helpful to determine what it is for sure though.
Old Apr 12, 2006 | 08:02 AM
HOsNiDA's Avatar
Sometimes you can get you oil leakage from your head. You could have already torque the head bolts down to much. Or you might be lucky and it be a Vavle cover gasket. But check that gasket first and go from there.
Old Apr 12, 2006 | 01:03 PM
Default Re: leaking oil from THAT corner (GTiMk3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTiMk3 &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes you can get you oil leakage from your head. You could have already torque the head bolts down to much. Or you might be lucky and it be a Vavle cover gasket. But check that gasket first and go from there.</TD></TR></TABLE>
they are AEBS head studs and havnt been torqued over 70 pounds and this is the second time ive used them in a new setup. the headgasket was new, the surfaces were resurfaced, its been doing it since day one, and it is NOT A SINGLE SEAL ABOVE THE HEAD, LIKE THE CAM CAPS OR DIZZY OR VTEC FOR THE LAST TIME!!!!!!! its getting smaller. I think its about to seal up.
Old Apr 12, 2006 | 06:23 PM
Honda Bull's Avatar
Mine leaks from there too... in fact... so do two of my friend's B-Series (one did before and after a rebuild). In fact, I've probably seen three other GSR's leak from there other than mine... and I haven't even been around Honda's for too long.
Most definately the headgasket, unfortunately. When I tried to figure out where mine was leaking, I Honda-bonded the cam cap and valve seal, and VTEC solenoid all over again. Cleaned all of the oil off. The oil came right back... from the head gasket. Oh well.
Old Apr 12, 2006 | 10:32 PM
PurEvl's Avatar
Default Re: leaking oil from THAT corner (Honda Bull)
copper seal the headgasket it first then put it all back together
Old Apr 12, 2006 | 11:10 PM
saccord's Avatar
Default Re: leaking oil from THAT corner (PurEvl)
yup you cant just slap a head gasket on and torque it down. you have to spray a sealer on it. and if you dont got copper sealer atleast try and find some black spraypaint or somethin. but most definetely get the copper **** if you can.
put it this way, i was replacing the head on my car. and my friend was replacing the head gasket on his.
i copper sprayed my head gasket, he didnt.
now his car leaks oil from that same spot, and mine is nice and clean.
what he learned was "use copper gasket sealer"
Old Apr 13, 2006 | 05:03 AM
Honda Bull's Avatar
Default Re: leaking oil from THAT corner (saccord)
I don't recall the actual name right now... but I wanna say "Indian Head" is a great head gasket sealer.
Old Apr 13, 2006 | 06:33 AM
haha i did copper coat it, i think i know why its leaking, i had to drill the dowel holes out bigger and i guess it was a little too rough between the layers after that preventing a full seal. OH well i have to change it soon anyways, i think i popped it slightly during tuning at 30 psi. lol
Old Apr 13, 2006 | 09:20 AM
DjChuckey's Avatar
so u just copper coated it,and it stop leakin?cuz im finishin up my B16 swap in my CRX and i have that exact saem leak, but it also looks like it is coming from the VTEC solinoid, and i really dont want to have that leak, it really does look bad :-\ ...
Old Apr 13, 2006 | 10:06 AM
Honda Bull's Avatar
Default Re: (DjChuckey)
No, he didn't copper coat it and it stopped leaking... it has deep issues.
For you, just get a new VTEC solenoid gasket, and Honda-bond it.
Old Apr 13, 2006 | 12:28 PM
HOsNiDA's Avatar
Dont for the last time me. Maybe that should be the first thing you should check.THERES NOTHING WRONG WITH GETTING YOUR HANDS DIRTY OR BEING WRONG EVERY NOW AND THEN.
Old Apr 13, 2006 | 03:31 PM
DjChuckey's Avatar
ok..thank you honda bull
Old Apr 14, 2006 | 04:22 AM
D-Rob's Avatar
Haha, funny I should see this thread.
I was out and about last night, and one of the local yokels has a GSR in his EG. His headgasket leaks at the same spot.
*knocks on wood* Mine's still good on my LSVTEC.
Old Apr 14, 2006 | 07:17 AM
Honda Bull's Avatar
Default Re: (D-Rob)
That local yokel doesn't happen to be Danny or I does it? LOL.
Old Apr 14, 2006 | 07:20 AM
D-Rob's Avatar
Default Re: (Honda Bull)
No, it's some guy with a teal EG with Si wheels.
But yes, Indian Head is what I used on mine. No leaks.
Old Apr 14, 2006 | 07:50 AM
Default Re: (D-Rob)
where do you get indian head
Old Apr 14, 2006 | 10:20 AM
robbieshonda's Avatar
Id say get a new headgasket and use copper coat because i have noticed that a few times on ls-vtecs and gsr motors
Old Apr 14, 2006 | 08:22 PM
Muckman's Avatar
Moderator in Chief
You sure your head dowel pins are installed correctly in the correct corners?
