Tranny/Fluid
Its automatic Use honda trans fluid very,very important its special now to fill pull the yellow handle dipstick and fill through their the dip stick is in the passenger side write in front of the battery down some times that dip stick rubber wears down so if its loose buy another one at honda is about $15 if not wrap some black electrical tape around it nice and tight then check the fit if its to tight remove some of the tape, now how much fluid if its totally empty it use almost 11 quarts if you just pulled the 3/8 plug it will take possible 4 t0 6 quart's I recommend put 4 quarts turn on car put in drive move it 5 feet go back in reverse move it 5 feet turn off car check fluid level good luck.
what i do when u flush out auto trannies is i drain it first, then i get the **** atf dexron 3 from autozone to flush it out. then i drain it out again and fill it with honda atf (about $9/qt). i fill it thorugh the dipstick. rides very well after wards
np, just get a long enough funnel, lol. i did about 2.5gt frist, ran through gears slowly. let it warm up, then turn off the car and immediately check teh dip stick [same method as oil] and added accordingly to a tad below the max line.
quiet4no1
Apr 2, 2009 10:59 AM
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
pelotudo
Jul 21, 2002 02:33 AM
