Help me Clear this questions about cluch master cylinder install
ok, i need to install cluch master cylinder, my question is, before i take off old
master cylinder, i need to drain fluid all the way empty? and put new and start
bleed them as filling in? other question is, is it bad after install new unit and push
w/o any fluid in the line or tank?? cause i heard that i will damage the valve in the
master cylinder?? please clear this questions for me. thanks
drain all the fluid, just leave the valve on the slave open and pump til it's slurping, remove mc, put in new mc, fill, and bleed. the valve will be fine.
Jon Petersen
Dec 23, 2018 02:47 AM
.water
Apr 3, 2006 07:56 AM
