Steering Jerk
Old Apr 1, 2006 | 11:55 PM
NoBottleJustThrottle's Avatar
Default Steering Jerk
Hey,
So this just started happening a couple of days ago. Its very random, happens very regularly sometimes, and very speratically others. Whats happens is, I will be shifting, accelerating, braking, or just crusing and I will feel just a very small jerk in the steering wheel. Its a jerk to the left, and its maybe just a couple of degrees, and then it just corrects itself right away. Its almost as though I am hitting something in the road that makes my steering wheel jerk, but its a little bit more violent.
As I say, I cant replicate it when I want. Its very much on its own. The most it happened was when I was heel-toe-downshifting on an offramp last night.
I popped my hood, the P/S belt is not loose. I let the car idle and I watch the belt, everything seems to be ok.
Any ideas? I have never come across anything like this before.
Thanks for the help.
Modified by NoBottleJustThrottle at 9:20 AM 4/3/2006
Old Apr 2, 2006 | 01:07 AM
Skynet's Avatar
Default Re: Steering Jerk (NoBottleJustThrottle)
I would say check the 17mm bolt at your lower control arm
Old Apr 2, 2006 | 05:54 AM
Dwight Schrute's Avatar
does it happen when you hit a bump? it could be bumpsteer... in which case you would want to check you steering rack.
Old Apr 2, 2006 | 09:32 AM
pro547's Avatar
would bumbsteer be caused by a bent inner tie rod?
Old Apr 2, 2006 | 10:58 AM
Default Re: (pro547)
No, its not even when I hit a bump in the road. As far as I can tell its completely random...which is weird. Sometimes it has one right after another for as many as 4 times. Sometimes its just once.
Old Apr 2, 2006 | 01:55 PM
Default Re: (NoBottleJustThrottle)
Bump.
Thanks for the help so far guys!
Old Apr 3, 2006 | 12:44 PM
boost'd_crx's Avatar
check tires/tire pressure, alignment, suspension
Old Apr 3, 2006 | 12:58 PM
Chunty Butt Kevin's Avatar
camber wear?
Old Apr 3, 2006 | 03:43 PM
Default Re: (Chunty Butt Kevin)
no camber wear what so ever. Tires are pretty new (maybe a month and a half). Thanks for the info though. Keep it comming guys.
I am going to check all the bearings, nuts, and bolts around my suspension this weekend.
Old Apr 6, 2006 | 11:30 PM
Skynet's Avatar
camber kit is loose if you have em
kevinhughes13
Dec 20, 2013 11:08 AM
buzlink
18
Nov 7, 2006 07:04 AM
TurboBumblBee
Apr 13, 2003 05:57 AM
fEEsh
Apr 12, 2003 06:27 PM
