Locking Lug nuts stripped....What should I do?
My 98 civic has 1 locking lugnut on each wheel and I dont have the key. When I looked at them more I can tell there are stripped so it wouldnt matter if i had the key anyway. I have tried everything and cant get them off. Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x »</TD></TR><TR><TD CLASS="quote">all you have to do is get a socket thats one size under the size that slips over the lugnut and then beat it on with a hammer</TD></TR></TABLE>
he cant get the one off that uses a key not the normal lugs read the original post
i did read it and i know exactly what he means...theres a size that slips right over the locking lug nut, then get the size right under that and beat the socket until it goes over the nut and then it comes off easy as hell
thats not the case sometime. i have gorilla lug nuts and they are circular on the outside and the inside for they is the shape of a clover there is no way you could do what you said to the ones i have. post a pic of the ones u have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x »</TD></TR><TR><TD CLASS="quote">ive used my method on the ones that are round on the outside with the clover inside...thats the ones i made it up on</TD></TR></TABLE>
i dont see how a HEX socket is gonna fit around a circular lugnut
no i dont waste it...it ruins the lugnut...but after i get the lugnut off i put it in my vice and put a screwdriver down the square that the ratchet goes in and give it a couple good hits and it comes out
purchase a 12pt socket thats not too expensive and take them out. you can use one for all 4 because lock lug is round its dont really going to tear up all the teeth inside. you can just hammer out the lock lug out of the socket with a screw driver.
I work at Pep Boys, and they have a socket set made espescially to take off locking lug nuts. We used it on a customer's ride, and it worked well.
Guest
Posts: n/a
try wd40 and try it again. If that doesn't work try to hammer a socket on but be warned you might brake the wheel stud and it will just spin around and you will have to cut it off and that's a b!tch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALLIN H22 EK »</TD></TR><TR><TD CLASS="quote">so basically u are wastin 4 sockets just to get off ur lugnuts when u could go to a rime and tire shop and do it for like 5 to 10 bucks..... sounds kinda dumb to me</TD></TR></TABLE>
Crapsmen er i mean craftsman sockets.. good for life time warrenty
Just go buy the ****** kit and call it a day or take it to a shop or use a smaller socket.
had it do this on mine, worked like a charm. and go get a craftsman socket to do it with. then take it back and replace it with a new one for free. sears is not allowed to ask why or what you did.
