USDM b18b into a crx
Old Apr 4, 2002 | 12:36 AM
spy54's Avatar
Default USDM b18b into a crx
alright i am looking for all info you can give me i know i will need engine, cable tranny, axles, ecu mounts, shift linkage time and patience but are their any like special things to look out for or such and it should be smog legal since it's usdm and it's newer am i correct?
Old Apr 4, 2002 | 12:48 AM
1st-hybrid's Avatar
Default Re: USDM b18b into a crx (spy54)
Well don't forget all the little things, ie. timing belt, new plugs, stuff like that. Also you'll probably need new spindles too. A helms manual helps as well. Also think a head and figure out what intake, header and exhaust you want to use, if your staying n/a that is. Do as much to the motor as you can before you put it in the car, and take your time. I'm in the middle of my swap, b18c1 into my hf, and I work on it on the weekends, and just take my time. So far so good for me, so good luck with yours.
Old Apr 4, 2002 | 01:41 AM
spy54's Avatar
Default Re: USDM b18b into a crx (1st-hybrid)
yeah but i got the emmission douche bags so do i wanna get al my perf parts b4 or after i go through that inspection?
Old Apr 4, 2002 | 02:50 AM
B16CRX's Avatar
Do things that are easier with the motor out before you drop it in the car. Like clutch, timing belt, water pump, etc... Then once you get through the smog inspection you have 2 years to do whatever you want to it.
Old Apr 4, 2002 | 04:51 PM
spy54's Avatar
Default Re: USDM b18b into a crx (B16CRX)
hey how did you pass with a b16?
Old Apr 4, 2002 | 08:01 PM
Urban Business
Guest
Posts: n/a
you'll need b series mounts, pound in the front lip on the cross member for trans clearence. an ef si harness will help emensily (need mpfi, hf isnt stock i believe). you will need an intermediate shaft for the drivers side axle.
new flywheel (lightened) or else have yours resurfaced
new clutch, timing belt, water pump, oil pump etc
IM superhatch hes doing this swap currently. i believe hes has all the wiring down now
Old Apr 5, 2002 | 09:12 AM
VTECVillain's Avatar
I'm working on a 96 B18B1 in my girlfriend's 91 CRX DX right now. I'll give you a detailed parts list of what I'm using which should help:
ENGINE: 1996 B18B1
TRANSMISSION: 1992 Integra LS cable tranny
CLUTCH/FLYWHEEL: 96 flywheel, 1992 Integra LS clutch + pressure plate, throwout bearing
ECU + FUEL: 1991 B18A ECU and distributor, 90 CRX Si injectors + resistor box, 90 CRX SI motor harness
MOTOR MOUNT KIT: HASport billet mounts
OEM MOUNT BRACKETS: 1990-93 Integra timing belt side engine bracket and rear engine bracket
AXLES: 1992-93 Integra LS axles
INTERMEDIATE SHAFT: 1992-93 Integra LS intermediate shaft
SHIFT LINKAGE: HASport shift linkage
THROTTLE CABLE: 1990 Integra
CLUTCH CABLE: 1990 Integra
UPPER RADIATOR HOSE: 1990 Integra - trim to fit
LOWER RADIATOR HOSE: 1990 Integra - trim to fit
When you buy all this stuff separate be prepared for all the "hidden costs" like bolts, hoses and crap like that. I bought all OEM bolts for the major components (flywheel, clutch, etc.) and spent about $100 on that!
I don't know anything about emssion laws because we don't have them thank god. I doubt you'll be able to use the older 90-91 distributor, ecu and injectors so you might have to do a full OBDI or OBDII wiring change to be legal.
[Modified by VTECVillain, 1:15 PM 4/5/2002]
Old Apr 5, 2002 | 11:31 AM
spy54's Avatar
Default Re: USDM b18b into a crx (VTECVillain)
wow that might be a tad bit annoying alright b/c i am trying to figure everything out, thanks for the info man i dont want to do a obd1 to obd2 conversion alright well hope yours goes well
Old Apr 5, 2002 | 03:45 PM
Speed PHreak's Avatar
Check out my website. The swap how 2 ought to answer a good bit of your questions. Anything else feel free to hit me up on PM's or AIM.
SiR Inspired ED7
Jun 5, 2009 08:59 PM
mynameizstitch
Sep 2, 2007 10:31 PM
moz92
Dec 28, 2006 11:12 AM
stripes777
Mar 8, 2004 09:37 PM
LSyellowREX
Jun 10, 2002 06:30 PM
