power window and sunroof problems
Old Mar 31, 2006 | 12:53 PM
B18Cej1's Avatar
Default power window and sunroof problems
(94 integra) they stopped working.. i have no clue why. i checked the fuses and they were ok. bothe driver's side and passenger side switches dont work. sunrrof switch doesnt work either. what can it be? thx
Old Mar 31, 2006 | 01:26 PM
Z3120's Avatar
Did you check all fuse locations? including the one under the hood?
Old Mar 31, 2006 | 03:42 PM
B18Cej1's Avatar
Default Re: (Z3120)
yea but nothing showed upp for sunroof or power windows
Old Mar 31, 2006 | 06:06 PM
sobecksi's Avatar
Yeah it's defiantly a fuse. It should say on the cover which fuse it is.
Old Mar 31, 2006 | 07:30 PM
B18Cej1's Avatar
Default Re: (sobecksi)
yea i checked the fuses. theres one for the sunroof and one for each window, they were all ok.
Old Apr 1, 2006 | 04:04 AM
travelor101's Avatar
Default Re: power window and sunroof problems (B18Cej1)
That is odd as hell. When I installed mine, I don't even think I remember seeing the extension for the sunroof outlet on the same line as the power doors. That is just a trip, because if the fuzes are not responsible for this, then you may want to trace your moonroof switch line and see where it connects to the under-dash harness. I know there is a main harness on the bottom and then a branch extension up top. I am thinking that if the fuzes are "completely" ruled out then something may have pinched the branch extension for both. Extremely doubtful though. Wish you luck.
rookierepair
Jun 7, 2024 05:02 PM
USA
Oct 2, 2021 03:13 PM
sam234
Aug 11, 2012 09:10 AM
Syke Fu
Honda Civic (2001 - 2005)
Oct 7, 2011 10:41 AM
HKJ
Mar 18, 2003 06:26 PM
