FS: CHIPPED ECU for B/D/F/H series! !!!****
Old Mar 31, 2006 | 12:03 PM
TypeRacer#1's Avatar
Default FS: CHIPPED ECU for B/D/F/H series! !!!****
Well Its a p28 Ecu
YET
I can have a Chip Burnt for your Application for it
Either for GSR, Type R, B16 or H22
Can set the following for you:
Increased Fuel Multipliers
Vtec Engagement
Secondary Engagment
Rev Limiter
Increase Fuel and timing Curves
Full Throttle
Adjust target Idle
Advance Injector Duty Cycle
Can disable following sensors:
Knock
ELD
Atmosheric Pressure Sensor
Injector Test Circuit
Oxygen Sensor( to run open loop)
O2 sensor Heater
Vtec Speed Check
Vtec Coolant Temp Check
Disable Speedlimiter
I need some money , that is why I am selling this Ecu
$160
CivicGSR00t
Dec 14, 2005 02:33 AM
1SlowB16EF
Jun 25, 2005 08:06 AM
B16aDasher
Oct 16, 2004 06:06 AM
