****CHIPPED ECU for B/D/F/H series! !!!****
Old Mar 31, 2006 | 09:58 AM
TypeRacer#1's Avatar
Default ****CHIPPED ECU for B/D/F/H series! !!!****
Tryign to get some extra cash to pay for tickets
So i'm selling my extra ECU
I can have a Chip Burnt for your Application for it
Either for GSR, Type R, B16 or H22
Can set the following for you:
Increased Fuel Multipliers
Vtec Engagement
Secondary Engagment
Rev Limiter
FULL THROTTLE LAUNCH ( turned on by A/C Switch....revs ur motor upto desired Rpm for perfect launch)
Shift Light ( Ur check Engine Light will blink to tell you to Shift)
Increase Fuel and timing Curves
Adjust target Idle
Advance Injector Duty Cycle
Can disable following sensors:
Knock
ELD
Atmosheric Pressure Sensor
Injector Test Circuit
Oxygen Sensor( to run open loop)
O2 sensor Heater
Vtec Speed Check
Vtec Coolant Temp Check
Disable Speedlimiter
SO WHAT U GET is a ECU AND a Removable Chip!
I need some money , that is why I am selling this Ecu
$175
ride201mph@yahoo.com
Umm i take paypal and Bank of America Wire Transfers only
mycivicsi
10
Sep 11, 2007 10:03 AM
CivicGSR00t
Dec 14, 2005 02:33 AM
1SlowB16EF
Jun 25, 2005 08:06 AM
