HELP to solve: Engine misfires, ECL
Old Mar 30, 2006 | 09:07 PM
les_sos's Avatar
Default HELP to solve: Engine misfires, ECL
I have Honda Civic SI '98 (109,000km)
Recently got CEL (Check Engine Light), took it to honda shop to have it tested
result: PGM misfire codes detected PO302, PO304;
They recommended to start with sprk plugs,
Replaced spark plugs Bosh Platinium
Problem persists, sputters a bit between 2500-3000 RPM and more over 3000.
OK on lower rpm,
Please provide me with the checklist of other potential mulfunctioning components.
Thanks in advance
les_sos
Old Mar 30, 2006 | 09:20 PM
95b16hatch's Avatar
Default Re: HELP to solve: Engine misfires, ECL (les_sos)
was there an o2 sensor code too? I know that honda put out a TSB on a common problem with a wire shorting out on the back side of the intake manifold that was throwing CEL. Do you have access to this info?
Old Mar 31, 2006 | 04:01 AM
les_sos's Avatar
Default Re: HELP to solve: Engine misfires, ECL (95b16hatch)
No, I do not. The only thing on the report is:
"PGM MISFIRE CODES PO302, PO304. REC START WITH SPARK PLUGS and RE ROAD TEST, REST ECU"
I replaced SPARG PLUGS and RESET ECU but problem continues.
r,
les_sos
Old Mar 31, 2006 | 04:46 AM
EE_Chris's Avatar
Are Bosch Platinum spark plugs the actual stock spark plugs for that engine? If not, get the correct plug. Your Si is our Ex, correct? Our Ex doesn't use those plugs.
What about the other ignition components? Cap, rotor, and wires? Have you run some injector cleaner through it lately?
Does the car have any mods or did you do any maintenace recently?
Old Mar 31, 2006 | 05:01 AM
les_sos's Avatar
No, mods;
Yes , Canadian SI is eq. to US EX
The car was for the routine maint .checkup 108,000km (67,500mi) just when after the first ECL showe-d up.
Did not run any injector cleaner nor checked cap, rotor or wires.
The plugs are not the type recommended in owners manual.
I'll need to do it tonight
r,
les_sos
Old Mar 31, 2006 | 05:17 AM
2lua's Avatar
use regular ngk, or denso plug, check the plug wires to see if it up to spec. 25k ohms.
check the plug wires order.
missfires at 2 and 4 cylinder.
Old Mar 31, 2006 | 05:28 AM
EE_Chris's Avatar
So are the cap and rotor original? As in, they too have 67,500 miles on them? They are way overdue for a service change, if yes. The wires should probably be changed too, but the cap and rotor need some attention if it's original stuff.
Old Mar 31, 2006 | 11:19 AM
les_sos's Avatar
Yes, Cap & Rotor & wires are original stuff. I get a replacement and recomended s.plugs & see if that helps.
Thank you for recommedations.
R,
leas_sos
MIKHAN
Aug 26, 2017 03:56 AM
soulraver
Honda Civic (2001 - 2005)
Aug 25, 2013 11:53 PM
rareturbobreed
Jul 19, 2011 03:27 PM
accord0494
Jun 25, 2011 06:48 AM
krazn
12
Nov 22, 2002 08:36 PM
