Help Please With Wierd Problem
This is a wierd problem that occured when my brother tried to help me out one day and been trying to figure out the problem for awhile. Well it started when I needed to get my emissions check again. I had Si-R gauges in my car at the time I swapped in my car a year earlier. But I heard people at the emissions place giving my buddies a hard time with their cluster swaps. So I decided to return mine to stock so I didn`t get a run around. Well my brother thought he would help me out and do it for me. But he forgot to disconnect the battery and/or something went wrong. Well it happened after I went to do the emissions check. I passed and went home and shut my car off. Turned my key and took it out and the car still ran. Couldnt figure it out. Finally I noticed my turn signals didn`t work and for some odd reason I hit the hazard switch and my car shut off. I tried everything to fix it. Installed the Si-R cluster, unhooked ECU and rehooked it up, checked fuses and nothing. So now I have to drive with no turn signals and hazard swicth is diconnected. Any clue on what had happened or a way to fix it? Also sorry for long post.
