tire question
Old Mar 30, 2006 | 07:00 PM
JDMInspired's Avatar
Default tire question
hi i currently am running 205/60/15's on my civic.. i am lowered 1.5inches.. i plan to change my tires soon and if i go to a 205/50/15 tire size how much lower will my car go.. because i scrape already on certain speedbumps.. i just want to know an exact loss of clearence i will get.. and if anything maybe post a before and after pic
Old Mar 31, 2006 | 08:25 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: tire question (JDMInspired)
The proper 15" size for your Civic is 195/60-15, which has exactly the same outer diameter (24.2 inches) as your stock 185/70-14 size.
205/60-15 is too big; the diameter is 1/2 inch larger than stock, and the tires are 20 mm wider than stock, which is why they are rubbing.
205/50-15 is MUCH too small for your car (4.7 percent, or 1.2 inches, smaller in diameter than stock).
You should be fine with 195/60-15.
Maireeka
Mar 26, 2007 08:05 AM
madlion
Oct 17, 2006 07:17 AM
tampabitches
Aug 24, 2006 01:26 PM
Beach Accord
Feb 1, 2004 08:57 AM
psyphre
Jul 11, 2003 09:13 PM
