Twin plate vs Single plate clutches
Old Mar 30, 2006 | 12:21 PM
Justin Olson's Avatar
Default Twin plate vs Single plate clutches
What are the main differences between a twin and single plate disk? Why do people go to twin plate clutches when they can get a single that holds? Is there a difference in pedal pressure and engaugement? Reliability?
Regards,
Justin
Old Mar 30, 2006 | 12:27 PM
.RTErnie's Avatar
Default Re: Twin plate vs Single plate clutches (Justin Olson)
If you've ever had a clutch come apart on you... You'll want to go overkill on every clutch you buy after that. I had a clutch destroy my trans, starter, radiator, axles, and my flywheel. CM stage 4 that broke around the spline.
Twins are on the majority lighter than single disk clutches due to their fully machined housings... typically lighter than the factory style pressure plate etc. Check out the 7.25" twins available from Tilton and Quartermaster(www.racingclutches.com) then you need to get a to bearing and a custom flywheel made.
Old Mar 30, 2006 | 12:29 PM
HybridKOOP's Avatar
Default Re: Twin plate vs Single plate clutches (~RTErnie~)
They also hold alot more power for a given "pedal" feel due to two discs absorbing the friction and heat as opposed to one.
Old Mar 31, 2006 | 03:27 AM
XXXRacing's Avatar
Default Re: Twin plate vs Single plate clutches (HybridKOOP)
You will also notice that a single plate will not want to disengage at higher rpms and you will miss shift alot. The twins don't have these same problems.
Old Mar 31, 2006 | 03:57 AM
Turbo-charged's Avatar
Default Re: Twin plate vs Single plate clutches (XXXRacing)
they also seem to help keep drivetrain parts together longer, dont seem to shock the driveline as hard
Old Mar 31, 2006 | 01:09 PM
Hondog's Avatar
Default Re: Twin plate vs Single plate clutches (Turbo-charged)
is there anyone that sells a complete kit, clutch and flywheel twin plate set-up
Old Mar 31, 2006 | 03:31 PM
paulzy's Avatar
all the ones I've seen come as a complete system...at least mine did
Justin Olson
Mar 31, 2006 05:20 PM
5thGenCivicKid
Dec 13, 2004 03:39 AM
stupidfast
Dec 11, 2002 03:58 PM
