motor problem
after cruizin down the freeway for 5 minutes at about 75 mph my car just like cuts out as i hold my foot steady until i let off and get back on again. then it will go for a sec and it will do it again. when i get off of the freeway it doesn't cut out after i come to a stop then go again. any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick »</TD></TR><TR><TD CLASS="quote">id say your throttle position tester. Cheap part and easy to replace, its the electronic portion that tells your engine howmuch throttle your pressing</TD></TR></TABLE>
yes your tps could be faulty or just not set properly... but if it is erratic while driving i would say it is a faulty tps (throttle position sensor*)
