Is this ecu salvagable?
Old Mar 29, 2006 | 04:02 PM
EgSalad's Avatar
Default Is this ecu salvagable?
Got this p28 from a buddy of mine.. and its damaged - you can see some burn marks on the board and whatever the little pice sticking up is is fried.
Is it salvagable? TIA
Old Mar 29, 2006 | 04:37 PM
Jim Truett's Avatar
Default Re: Is this ecu salvagable? (EgSalad)
Yep, it's salvageable. $20 plus shipping is my going rate.
Old Mar 29, 2006 | 10:02 PM
FaceTuned's Avatar
just take q31 out they alwayz burn up for some reason like p72 and p28's just move it back and fourth until it brakes loose you shouldnt have any props/
and im speaking from experience.
Old Mar 29, 2006 | 10:57 PM
mtber's Avatar
Its fine, looks like someone crossed iat with egr.
Old Mar 30, 2006 | 12:35 PM
TypeSiR's Avatar
Default Re: Is this ecu salvagable? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Its fine, looks like someone crossed iat with egr.</TD></TR></TABLE>
but a p28 doesnt have a egr?
Old Mar 30, 2006 | 02:41 PM
EgSalad's Avatar
Default Re: (jdmhatchness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness &raquo;</TD></TR><TR><TD CLASS="quote">just take q31 out they alwayz burn up for some reason like p72 and p28's just move it back and fourth until it brakes loose you shouldnt have any props/
and im speaking from experience.</TD></TR></TABLE>
q31 is the burn piece?. If so, cool deal. Ill do it. If I do break it off, will it present problems with things like the IAT?
Old Mar 30, 2006 | 03:14 PM
FaceTuned's Avatar
i never have probs after that mostly every obd1 p28 or p72 i take q31 out they burn up alwayz just take it out itll run fine
Old Mar 30, 2006 | 03:59 PM
EgSalad's Avatar
sweet.. thanks for your help.
Old Mar 30, 2006 | 04:39 PM
FaceTuned's Avatar
no prob
Old Mar 30, 2006 | 08:25 PM
Jim Truett's Avatar
EVAP Purge solenoid, not EGR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness &raquo;</TD></TR><TR><TD CLASS="quote">i never have probs after that mostly every obd1 p28 or p72 i take q31 out they burn up alwayz just take it out itll run fine </TD></TR></TABLE>
They only burn out when the IAT and EVAP Purge connectors are swapped.
If your state has strict emissions standards, you may need Q31 functional. If not, you should be fine.
Old Mar 30, 2006 | 09:45 PM
FaceTuned's Avatar
are you sure, every car ive ever put a p28 with q31 runs fine for like 5 seconds and then bam burns rite up, are you sure its iat?
Old Mar 30, 2006 | 09:51 PM
FaceTuned's Avatar
q31 is for the evap,
thumbsup EL jim
Old Mar 31, 2006 | 05:16 PM
TypeSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness &raquo;</TD></TR><TR><TD CLASS="quote">are you sure, every car ive ever put a p28 with q31 runs fine for like 5 seconds and then bam burns rite up, are you sure its iat?</TD></TR></TABLE>
after you take that out, do you still have a check engine light?
Old Mar 31, 2006 | 11:27 PM
Jim Truett's Avatar
Default Re: (TypeSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSiR &raquo;</TD></TR><TR><TD CLASS="quote">
after you take that out, do you still have a check engine light?</TD></TR></TABLE>
If you have the EVAP and IAT plugs swapped, yes. You most likely have melted your IAT sensor and need a new one if that is what happened.
Old Apr 1, 2006 | 07:44 AM
TypeSiR's Avatar
Default Re: (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">If you have the EVAP and IAT plugs swapped, yes. You most likely have melted your IAT sensor and need a new one if that is what happened.</TD></TR></TABLE>
i havent melted anything, im trying to find out if i can use this method and old ecus will work again.
fktouge
Nov 26, 2007 12:49 PM
mitsuman
May 25, 2007 09:53 PM
92CiVicSI79
Apr 10, 2007 07:17 AM
hany
Nov 21, 2006 11:44 AM
Cyphear
Aug 5, 2004 06:11 AM
