Question about engine corrosion
Old Mar 29, 2006 | 03:25 PM
drewbie's Avatar
Default Question about engine corrosion
How do you get this stuff off?
I'm not a chemistry major so the only guess I have is steel wool, or acid. I don't know much about alluminum
Old Mar 29, 2006 | 03:38 PM
dangle's Avatar
Brake cleaner? Its strong so I use it for everything at work. Just try not to get high off the stuff...
Old Mar 29, 2006 | 03:52 PM
drewbie's Avatar
Default Re: (dangle)
Brake cleaner is a power solvent. I think its just like acentone.
I was thinking of someting that would react with the corrosion. LIke tarnish remover for Silver spoons and acid for cleaning cement.
Old Mar 29, 2006 | 03:56 PM
EG2Driver's Avatar
Default Re: (drewbie)
you could try CLR?
Old Mar 29, 2006 | 04:18 PM
WishinItWas's Avatar
Default Re: (deadend9009)
bumo for more info some one has to know of something made for this
Old Mar 30, 2006 | 07:12 AM
drewbie's Avatar
Default Re: (WishinItWas)
I heard that somone used something called CRC. I dunno what it means.
So far the only method I've found that people say works is acid. Or sandblasting.
And Ive also read not to use steel wool because the fibers will get trapped in the block and rust....
Those guys said the corrosion of alluminum is a natural protectant, like bark on a tree.
But, mine is like the picture and its OUT of control.
and I think if I were going show, I'd powder coat the block.
Old Mar 30, 2006 | 07:28 AM
dpkelly's Avatar
Powder coat like this guy did:
http://www.honda-acura.net/for...29827
Old Mar 30, 2006 | 07:44 AM
fmrprojects's Avatar
Default Re: (dpkelly)
get the block clened out at a machine shop. they have all the solvents to clean any part
Old Mar 30, 2006 | 07:56 AM
The One Upper's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">get the block clened out at a machine shop. they have all the solvents to clean any part</TD></TR></TABLE>
DING DING DING We have a winning answer for andrew
satterfi
Jul 14, 2009 04:20 AM
clem kevin
Aug 11, 2008 04:02 AM
zipoton
Apr 22, 2008 03:42 AM
spankey167
Nov 19, 2003 10:53 PM
monsta
May 29, 2002 12:04 PM
