throttle cable and bracket problem
ok hey guys I have done research on this but cant get a straight answer I have a 1997 civic hatch with a b20 with a gsr head with a skunk2 throttle body with a skunk2 intake manifold pro series so what throttle cable and bracket can I use for this rit now i just have it rigged but doesnt work all that great thank for the input guys
Re: throttle cable and bracket problem (BlueIntegraBoy)
what bout a gsr or type R cuz thats what I was told by some other people are they wrong or would they still work???
Re: throttle cable and bracket problem (young O)
but they are skunk2 or is that what ur talking bout cuz its aftermarket I wouldnt be able to use that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young O »</TD></TR><TR><TD CLASS="quote">but they are skunk2 or is that what ur talking bout cuz its aftermarket I wouldnt be able to use that </TD></TR></TABLE>
Yeah, Sk2 IM is like a Type-R IM and I believe the TB is like the ITR one as well, use the Type-R or Si throttle cable.
if you are using a intake manifold from skunk2 then heres a list of the parts that will work
throttle bracket
-intega type r
-del sol b16
-civic b16
throttle cable
-integra type r
-del sol b16
-civic b16
-integra ls gs rs
if your using a skunk 2 manifold then type r bracket and cable will work best because everything is matched with the manifold you bought, but they all work the same, and they all cost the same at the dealer. i have a blox manifold on my gsr and i used a type r bracket and cable. if your using a b16 manifold use the b16 bracket and cable you get the idea. i hope that helps
throttle bracket
-intega type r
-del sol b16
-civic b16
throttle cable
-integra type r
-del sol b16
-civic b16
-integra ls gs rs
I have a 93 hatch with a 00' LS engine and the Skunk 2 IM. I am using the LS cable that came with the motor all I had to change was bracket. You will need to use a Type R bracket they are about 7 bucks from honda. Like I said I am using an LS throttle cable and mine works perfectly fine. If you have a GSR head then use the GSR cable I would assume.
fred92htch
04-07-2003 07:55 PM
