Repainting Rocker Panels (what paint to use?)
Old Mar 29, 2006 | 02:53 PM
Maxximtl's Avatar
Default Repainting Rocker Panels (what paint to use?)
Over time the black portion on the lower rocker panels has deteriorated due to rock chips, ect. I want to repaint that portion just to improve the appearance. My question is, what paint product should I use for that area? Would an undercoating type product be appropriate, or should I stick with a traditional paint? I basically want to restore the matte finish.
Old Mar 29, 2006 | 03:01 PM
Tippyman's Avatar
Duplicolor Trim Paint. (in the green can!)
It's the ****!
Old Mar 29, 2006 | 03:10 PM
Tippyman's Avatar
Default Re: (Tippyman)
Here: https://honda-tech.com/zerothread?id=489625
Old Mar 29, 2006 | 04:11 PM
Maxximtl's Avatar
Actually, I am referring to the metal underbody rocker panel (mine doesn't have the plastic pieces.)
Old Mar 29, 2006 | 06:04 PM
Branman's Avatar
Default Re: (Maxximtl)
i have a civic also, bump to find out.
Old Mar 29, 2006 | 07:38 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxximtl &raquo;</TD></TR><TR><TD CLASS="quote">Actually, I am referring to the metal underbody rocker panel (mine doesn't have the plastic pieces.) </TD></TR></TABLE>
If its the spot i think you're talking about, then some undercoating products might be the best bet. I think u can get the stuff at autozone or kragen. Trim paint or anything similar to it probably wont do too well b/c that particular area is prone to rock chips. The undercoating stuff is rubber like (less prone to chipping away). Only thing i dont know is how glossy the undercoating stuff is.
Old Mar 29, 2006 | 08:12 PM
boostedblkef's Avatar
i used a type of undercoating that i got from an automotive paint storeand it actually hardens like a shell and then it can be painted to match im not sure of the exact name of it but go to auto pain store and tell them what your lookin for and they can help if i find out i will post it up
Old Mar 29, 2006 | 08:43 PM
Maxximtl's Avatar
Default Re: (pitbullracer)
thanks for the help guys.
Old Mar 29, 2006 | 10:18 PM
Duncan90si's Avatar
You can even undercoat it first then spray it with trim black. Just make sure the undercoating specifies that it is paintable, if it doesn't you'll have a big mess when you try to spray over it. I learned the hard way.
em Dot
13
Jun 14, 2007 08:19 PM
turbotime
17
Mar 29, 2007 07:50 PM
deadlock32
Welding / Fabrication
Jun 26, 2005 07:53 AM
infinitetruth
11
Jun 24, 2004 02:50 AM
speedaccordinly
Sep 8, 2003 01:26 PM
