Check engine - Primary heated oxygen sensor slow response
Old Mar 29, 2006 | 04:57 AM
mrmanuke's Avatar
Default Check engine - Primary heated oxygen sensor slow response
According to my manual, this sensor controls the air/fuel ratio. I just bought this car, and it has a VAFC installed, which also controls air/fuel ratio, correct? Is it important to take care of this sensor?
The manual also states that the MIL comes on after deterioration of the sensor is detected during two consecutive trips. So if I turn off the ECU memory and turn off the car, I shouldn't get this CEL again the next time I turn on the car, should I? I've got a switch wired to do this ( http://www.ntpog.org/mods/fifth-afc/ecu.shtml ), but no matter which way I flip the switch, the MIL stays on every time I turn on the car. Any ideas/advice?
EDIT: I think I don't have an ECU memory switch, rather it's a valet/bypass switch for my alarm system.
Modified by mrmanuke at 6:23 AM 3/29/2006
Old Mar 29, 2006 | 01:55 PM
mrmanuke's Avatar
Default Re: Check engine - Primary heated oxygen sensor slow response (mrmanuke)
is this a problem that needs attention? Since it only detects a problem after two consecutive trips, I think I can keep the problem from being detected by the ECU if I wire an ECU memory switch so that it forgets the sensor's slow response time every time I turn off the car. Good idea? Bad idea?
Old Mar 31, 2006 | 07:56 AM
aztecwhitelude's Avatar
Save yourself the hassle and just buy an O2 sensor and install it. Best to be safe then sorry!
MadcapAlex99
Mar 30, 2019 05:04 PM
hatchout01
Sep 25, 2015 06:45 PM
ONEFASTJDM
Jul 16, 2009 10:37 PM
djay86
Jul 30, 2002 11:39 AM
