need help on a good head set up for turbo gsr
Old Mar 28, 2006 | 09:40 PM
gsrboosten's Avatar
Default need help on a good head set up for turbo gsr
got a 2000 gsr turbo but cant decide wat head set up to go with got any advice the block is gonna be runin pistons rods and a block guard
Old Mar 28, 2006 | 09:42 PM
Dartanian's Avatar
Default Re: need help on a good head set up for turbo gsr (gsrboosten)
Can you be more specific on bottom end reinforcements?
Headwork is the last thing you should be worrying about on a boosted setup. The only thing that you should consider is a set of cams until the bottom end is fully built up.
Old Mar 28, 2006 | 09:44 PM
gsrboosten's Avatar
Default Re: need help on a good head set up for turbo gsr (Das Schmoo)
typer rods crower pistons forgot the block guard
Old Mar 28, 2006 | 09:47 PM
Dartanian's Avatar
Since when does Crower make pistons?
You will want a forged rod to go with the pistons. Cast rods are junk.
Old Mar 28, 2006 | 09:58 PM
gsrboosten's Avatar
my bad i ment the rods and the pistons are type r
Old Mar 28, 2006 | 10:07 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrboosten &raquo;</TD></TR><TR><TD CLASS="quote">my bad i ment the rods and the pistons are type r</TD></TR></TABLE>
Type R pistons won't even fit on those rods. And plus, they are cast and higher compression than you want. You need to do more research on this.
Get forged rods, forged pistons, and skip out on the block guard.
Old Mar 28, 2006 | 10:12 PM
gsrboosten's Avatar
thanks bro ill look into it wat would be a good set up for the head then
Old Mar 28, 2006 | 10:21 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrboosten &raquo;</TD></TR><TR><TD CLASS="quote">thanks bro ill look into it wat would be a good set up for the head then
Stock.
Focus on the bottom end and proper fuel management if you want the setup to last. There has been plenty of power made with the stock head and cams.
eg4life1202
10
Dec 1, 2018 11:05 PM
sivic_si
Nov 11, 2006 10:42 AM
popuppiston
Aug 12, 2005 03:45 AM
hitvtecgetloud09
Aug 5, 2004 06:58 PM
niedejb
Jul 16, 2002 04:44 PM
