Highest Compression on pump gas
Old Mar 28, 2006 | 07:12 PM
tomu06's Avatar
Default Highest Compression on pump gas
Hey guys what the hightest compression ratio you can have on 92 octane pump gas? Going in LS/Vtec w/ B16 head...
Old Mar 28, 2006 | 07:53 PM
urbansi's Avatar
Default Re: Highest Compression on pump gas (tomu06)
I wouldnt push past 13:1, for a daily driveer i would say around 12-12.5
Old Mar 29, 2006 | 09:42 PM
tomu06's Avatar
Default Re: Highest Compression on pump gas (urbansi)
anybody else have any inquiries?
Old Mar 30, 2006 | 03:27 AM
so lazy's Avatar
ive got 12.4 on my b20vtec still and im running on 93octane nothing seems to be happenning... I drive it almost everyday..
Old Mar 30, 2006 | 12:56 PM
orso's Avatar
depends on tuning. i would say 11.0-11.5 for everyday driving. more than that and you are starting to push the driveability factor.
Old Mar 30, 2006 | 03:07 PM
Scott_Tucker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomu06 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys what the hightest compression ratio you can have on 92 octane pump gas? Going in LS/Vtec w/ B16 head...</TD></TR></TABLE>
Static compression ratio and octane rating are not really related. You need to build the engine around what you plan to do with it. An engine with a higher static compression ratio will require more duration on the cam to keep cylinder pressures low enough so the air/fuel mixture does not auto-ignite (detonate).
For a daily driver you probably don't want to go past 12.5:1, like the previous poster said. That being said though, the RPM the engine makes max power will be lower than an engine with, say, 13.0:1 If you want a higher reving engine you will need to go higher on the compression ratio.
I wrote a short paper on cams vs. compression ratio stored in my notepad if you want me to PM it to you later.
typer161
Jun 2, 2009 05:34 PM
hondab18civic
Feb 6, 2006 07:12 AM
vegan_punk
Apr 8, 2003 08:55 AM
wickedEFguy
Feb 3, 2003 11:14 PM
Spoold_R
May 12, 2002 06:44 PM
